Celsius to Fahrenheit in tunerpro
Old Sep 19, 2010 | 03:29 PM
profootbrake2's Avatar
Car: 92 Camaro Z28
Engine: ZZ4 TPI
Sorry for this amateur question but is there a way to have tunerpro use Fahrenheit instead of Celsius for the temperature
Old Sep 19, 2010 | 05:54 PM
malcom2073's Avatar
Car: 1987 IROC-Z
Engine: 383ci SBC
Re: Celsius to Fahrenheit in tunerpro
For your datastream, if you go into the datastream definition you can change the function used to calculate the value from the raw bytes. For the actual calibration values, you would need to edit the XDF itself to change that.
If there's a simpler way, someone please chime in, but this is how I changed mine to be consistent, since temp returned is in F, and a bunch of the calibrations are in C which is very annoying to try and convert on the fly.
Old Sep 21, 2010 | 10:16 AM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
almost every calibration uses the equation X*.75-40 for *C. to convert that into *F, switch the .75 with 1.35.
Old Sep 21, 2010 | 09:49 PM
Car: 92 Camaro Z28
Engine: ZZ4 TPI
Thanks for the replys i will try to change it when i get time
junkcltr
26
Jan 22, 2022 10:53 AM
Mark_ZZ3
May 24, 2018 01:02 PM
Toolsin
Feb 2, 2016 06:55 AM
ULTM8Z
Oct 2, 2015 01:25 PM
tmellott89
Aug 16, 2015 02:58 PM
