? About MAF Ecms
Car: Corvette
Engine: 388 HSR custom Cam see sig
Axle/Gears: D44 3:45
? About MAF Ecms
I've been curious, if you have a MAF ecm ( say 165) that is to be used with a MAF car can you eliminate those tables in the tune and use as a SD system? or use a mask?
Car: check
Engine: check
Transmission: check
Re: ? About MAF Ecms
Note that it only supports 160 baud ALDL.
This mask has been discussed here quite a bit. So should be able to turn up information on it here.
RBob.
Car: Corvette
There is an Aussie SD BIN that can be used in the '7165 ECM. Can't recall the exact Mask ID, but something like $5B comes to mind.
RBob.
RBob.
BTW my tune as come together quite a bit. A few areas still left to work on but its a totally different car. All this and in just a few weeks I'm putting in a 388 roller..it never stops
Car: check
Engine: check
Transmission: check
I found this, I know that there is more info here. But it is a start:
https://www.thirdgen.org/forums/diy-...holden-v6.html
It also gets easier as you work on the tune. Good to hear that it is running the way it should.
Rbob.
Rbob.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Tequilaboy has done a pretty good job recoding the '165 to run a ford MAF. He's running a powerdyne blower on his C4 with success if I recall. Might be an option for you, especially if you want to keep the dash specific components in your C4.
-- Joe
-- Joe
efiguy
Sep 27, 2015 01:30 PM
86White_T/A305
Sep 21, 2015 05:28 PM
