few questions on burning prom
Car: '91 formula 5 speed
Engine: 5 oh
Transmission: manual T5
Axle/Gears: 3:43
hey all i tried to read the stickies on this but its alot of info. i understand the principles of burning chips, but my questions are where can i get such software and how much am i talking for an investment in this. i got a speed density 91 305 tpi, i want to do some work an can get a race prom for 140 bucks but if id be into the software for that or a little over id just invest an burn my own. thanks an sorry but i want to get to the core of the matter an decide what i want to do.
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Re: few questions on burning prom
Car: 69 Camaro
Engine: 355 SBC
Transmission: Glide
Axle/Gears: 4.88 full spool
I would definately buy the stuff to do it yourself. To get started with basic stuff you will spend about the same as the "race prom" and be alot better off. It will take some research and a learning curve but that is the fun of it. www.moates.net
Engine: 5 oh
Axle/Gears: 3:43
thanks guys, that link you gate me gta answered my questions with all the links you had posted. so its looking to be around 400 bucks to get started, would this software only be used on a gm or could i tune a mustang as well?
Car: 1989 T-Top GTA
This software (TunerPro RT) is for GM OBD1 only as far as I know....
Looks like TP RT has a ford version on the Moates website but I have NO idea how any of that works.... GO PONTIAC!!!! hahah
http://www.moates.net/ford-pre2005-c-63.html
Here is tunercat: tunercat.com.
To datalog I began with winALDL again very basic and I will say easy to understand.
You can erase stock chips but need a UV eraser, then you can burn stock chips but need a burner and even then they seem to be very unreliable. From a guy who went that route I would say just jump up a few more bucks and go with the AutoProm from Moates. It will not erase a stock chip or program a stock chip but will read them. With the AutoProm you need an adapter for your ECM then you can use an erasable re programmable and very reliable Flash chip. No need for a UV eraser.
With AutoProm and TunerPro software which is included with the AutoProm you will have Data Logging, Real Time changes while you drive and a chip burner when your done. I don't think theres a better alternative available at any cost. HTH
Car: '74 Firebird, '84 vette
Engine: 454 twin turbo, 350 HSR
Transmission: 4L80E, 700R4
Axle/Gears: 9", Dana36
It can be done even more inexpensively than that.
You need at least the following;
1. Burner. moates Burn2 runs about $85.00 I think
2. ALDL cable. I use the one from aldlcables.com It was $59.00
3. Flash chip(s). I use SST27SF512 chips. check ebay, also Xenocron has them for 4.00
4. TunerproRT software
I take a stock memcal and remove the stock eprom and solder in the flash chip. I have a really basic adapter made for my burner that is nothing more than some header pins and radioshack perfboard which allows me to just plug in the memcal. Cost for the adaptor is about 2 or 3 dollars total.
once you have the basic equipment to burn and scan you can reprogram as many cars as you wish for about $4.00 each.
All other products such as G3 adapters, wideband sensors and eprom emulators will make it faster and more convenient, but you can get started with what I have listed above.
Car: 69 Camaro
Engine: 355 SBC
Transmission: Glide
The punisher is talking about the way that I went. I have used this method for years with no problem. Lots of fun! and simple
Engine: 5 oh
Axle/Gears: 3:43
right but with the adaptor an autoprom all the soldering can be eliminated, although if i did go that route it would save me 200 bucks hmmm, i can solder good, got a fine prong solder gun also
Engine: 5 oh
Axle/Gears: 3:43
and another thing i think its non heterosexual that i have to buy the tunerpro software PLUS the 330 dollar autoprom, it should come with it
Tuenrpro and autoprom are made by different people and are separate products. Also tunerproRT has a 10 second NAG window if unregistered, but you can get started without buying, and pay your thanks when you can afford it. The price for this EXCELLENT software is VERY reasonable(unlike some other tuning/scanning software).
