Not getting closed loop.
Old Apr 3, 2011 | 03:40 PM
camaro87-alex's Avatar
Car: 1987 Chevrolet Camaro SC
Hi there...
I have problem getting the engine in closed loop mode.
After I installed headers I tought that it was because temperature so I got a wideband instead since I was going to tune the engine also.
Still the engine shows open loop mode in TunerPRO.
I have done some modifications to the engine so I needed to tune the MAF tables and the Timing Advance table a little bit.
Anyone knows what could cause this??..I guess it just have to be something with the tuning.
It is a 305 MAF engine tuned with 6E in TunerPRO.
Old Apr 3, 2011 | 07:23 PM
helo's Avatar
Re: Not getting closed loop.
can you post a tunerpro .csv log? it's hard for anybody to just guess.
Old Apr 3, 2011 | 08:09 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Did you change the temp to go into
closed loop
Old Apr 4, 2011 | 11:20 AM
I post one now so you can have a look. This is a week old trip though so I have done some small tuning mods since that time also.
I know the TPS isn't correct so that is adjusted and I have also leaned out some of the MAF tables.
Anyway, please take a look. It is compressed in ZIP format.
closed loop
Yes I did change the temp. I think I changed it to about 120 degrees.
File Type: zip
Old Apr 5, 2011 | 10:31 AM
helo's Avatar
Your o2 sensor isn't doing what it needs to for the PCM. Look at column Q. It should be bouncing from like 850mv down to maybe 200 with very high frequency, but it's floating at a near-constant 450mv.
You don't want a wideband o2 for the PCM to use, just get a 4-wire sensor (heated). Wire the heater element to the fuel pump hot wire, oil pressure switch, or the ignition circuit. Fuse&relay is good, but not required.
Delphi ES20317 is $42 on amazon. The proper connector can be found on 96+ chevy trucks (4.3/5.7), and probably a range of other vehicles.
Old Apr 5, 2011 | 02:55 PM
I have the wideband Lc1 kit and that wideband sensor works like a narrow band sensor to the ECM if I connect it correctly.
Other than that the wideband sensor is working perfect on my AFR gauge.
Could this fault mayby come from a short to ground or something like that?
Old Apr 5, 2011 | 04:50 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
From the data log it actually looks like the sensor is disconnected. Usually, even with the sensor downstream it will wake up once the vehicle is being driven.
RBob.
Old Apr 5, 2011 | 05:15 PM
RBob.
Sounds like the same to me actually. But I don't understand why because everything is wired up correctly. I connected the LC1 as the instructions told and that wideband works perfect. And the instructions told that if I wanted to connect the wideband to a PCM I could connect the brown wire to the 1-wire output for the sensor from the ECM. So I cut the D7 wire at my stock 165 ECM and connected the brown wire to that pin.
I think I have to check that all the ground are connected correct.
Old Apr 5, 2011 | 09:53 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Double check the programming of the LC-1 itself.
Might be the cause of the alternate output not doing what you think.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Pac J
May 17, 2020 10:44 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
