Aftermarket Eprom Question
I bought 2 aftermarket chips for a 350 SD. TPI, AUJP- from 2 different well known TPI companies. What I would like to know is there a way to tell if the
Eprom they sent was orginally from a 350 TPI SD?? The 2 Eproms are very
different from each other. One even has a (what looks like a resistor) soldered to one of the small chips?
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: Aftermarket Eprom Question
Might be able to figure it out using some of the info in this thread.
https://www.thirdgen.org/forums/diy-...49-memcal.html
