L98 Prom Questions
Old May 21, 2011 | 07:58 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
L98 Prom Questions
Ok so im new to the whole ecm side of the thirdgens and im having an issue with my l98 swap, my ecm i ordered has a v6 memcal and as far as i know i cant use that for my tuned port correct? Ive got the 7730 ecm, it just has a v6 memcal, ive been offered an ADBR by another member but when i googled it i couldnt find anything
To my knowledge i need a v8 memcal out of a 90-92 tpi car right? V6 wouldnt run in limp mode for a memcal.... sooooo since im on the search for a very specific memcal is there any way i can get a list of usable ones? ive been told i can use a 305 one as well but im not sure if thats correct
sorry for my ignorance ive been around the boards for years and this is honestly my first time coming into the DIY PROM section lol
Thanks in advance
Old May 23, 2011 | 12:06 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: L98 Prom Questions
Bump?
Old May 23, 2011 | 07:12 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It won't run in limp mode, just have the wrong injector firing rate and the wrong spark timing.
Are you going to tune it yourself? If so you can use that MEMCAL. Just need to make a few changes to it.
RBob.
Old May 23, 2011 | 10:39 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
RBob.
The v6 one? Really? That would really help right now, and yes a friend is burning me a prom for it
Old May 23, 2011 | 11:47 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Ground pin 56 of the MEMCAL. That will set the correct injector firing rate. For the PROM, can either: use a G1 adapter (moates.net), remove current and replace with socket, erase current and re-burn.
The knock filter and limp mode calibrations won't be correct. But in a pinch this works.
RBob.
Old May 23, 2011 | 12:04 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
So as long as I dont throw a code I should be fine correct? The knock settings is my biggest concern though
Old May 23, 2011 | 05:10 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
A code doesn't put the ECM into limp mode.
RBob.
Old May 25, 2011 | 12:16 AM
JamesLLeary's Avatar
Car: 1986 K10 Suburban
Engine: 5.7 TPI Speed Density
AUJP would be the one you want, if you can`t figure out the v6 memcal.
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
