guys who've dyno tuned their engines
Old Jul 2, 2011 | 12:51 PM
ULTM8Z's Avatar
What's your setup (heads, cam, manifold)?
What AFR did you end up with at max power?
Old Jul 3, 2011 | 10:45 AM
ULTM8Z's Avatar
Re: guys who've dyno tuned their engines
One thing I'm interested in knowing too is, if you tuned with a wide band, how well does the programmed PE value correlate with what the engine is actually doing? I.e., if you programmed in 12.3:1, do you see 12.3:1 on the WB or is it very different?
Old Jul 3, 2011 | 11:23 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
AFR 195 headed 383 at 11 to 1 compression, ported holley stealth ram made best power at around 12.9-13.0 to 1. I do not know the programmed PE value vs actual tho.
I never logged it to see what commanded Air fuel was at WOT. I may beable to figure that out by the bin file but not sure.
Another stealth ram car I did abit of dyno tuning on but mostly track tuning seemed to do best at 12.6-12.7 to 1 but we only did 3 pulls to see what was going on. I didnt get a chance to really smooth out the curve. It started at closer to 12.2 to 1 and tapered off to 12.8 or so but suffered valve float so we didnt mess with it too much more.
Now on that setup, commanded air fuel was 11.22-11.26 to 1 and it was basically a whole point off that and then some.
1992rs/ss
Jan 31, 2025 05:10 PM
MustangBeater20
Oct 29, 2022 09:20 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
