L98 What Eproms can be used
Old Jul 4, 2011 | 02:51 PM
95wagon's Avatar
Hello, when using a removable Flash chip and Moats adapter in a 90 speed density L98, how close does one need to be with the original Eprom? Are there easier to find substitutes ?
Correct me if I am wrong, the Eprom in this application is only doing knock sensor related and limp mode functions?
Thanks, Gerry
Old Jul 5, 2011 | 11:32 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: L98 What Eproms can be used
Thanks, Gerry
The MEMCAL does this function by way of two resistor chips and the knock filter built into it.
The EPROM is also part of the MEMCAL but is bypassed using a Moates adapter so your chip is used. The EPROM has the entire operating code on it to run the engine. Anything in there can be changed by burning a new chip the other items are not easily changed.
You should start with a V8 MEMCAL of the right displacement if possible so the chip resistors are close (you might make it home in limp) but if you have alot of mods it doesn't work well. The knock sensor and filters work together so the wrong displacement MEMCAL doesn't work well with the wrong knock sensor. Try to keep the setup matched for best results.
Using the V6 MEMCAL can be done but the limp settings will be worse and the knock stuff as well.
Old Jul 5, 2011 | 11:56 AM
95wagon's Avatar
Sorry , mixed terminology
So, best to find a speed density L98 memcal
If not V8
If not V6 and shut off cylinder select code in flash
Old Jul 5, 2011 | 09:11 PM
JP86SS's Avatar
The cylinder select is a hardwired thing as well as a software setting.
Be sure to do both if going thatroute.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
91chevyz28
Feb 10, 2022 07:58 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Tarizza
Sep 24, 2015 12:57 PM
