Need help, trouble with $32B in Tunercat
Old Jul 16, 2011 | 10:25 PM
pontiacjeff's Avatar
Hello, I read the chip with my PP2 and it tells me I need a $FF, which sounds suspicious to me. I think I got a bad Memcal. The check engine light was on, no fuel pump prime, and the fans ran when key on, engine off, like it was in limp mode. Now with it not recognizing the #32B file, I'd say the latter. It would start (eventually) and run ok, but like it was in limp mode with no timing at all.
So I have all my Moates stuff, piggy-back chip adapter and two chips, can I just start out with a stock bin file and not worry about the bad chip on the stock Memcal? Or do I need a good Memcal? And where can I find a stock file for an 88 305 TPI? (not begging, just asking.)
Old Jul 17, 2011 | 08:14 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Need help, trouble with $32B in Tunercat
Asking for stock calibrations is entirely permissible. Check Mike's site:
http://www.eecis.udel.edu/~davis/z28
Can also hit www.moates.net, in the fileman area.
As long as the MEMCAL you are using is for a V8 you are good to go. The reason is that it sets the injector firing rate per the number of cylinders.
RBob.
Old Jul 17, 2011 | 01:11 PM
Thanks! I'll try to find the one I need. I have been tuning 2L turbo, Quad 4, and 60deg V-6 for 10 years, except for a LT1 Impala, this is the first V-8 I've done! I have a dozen Memcals, but obviously the will not work.
One more thing I noticed, this Memcal (88 305 TPI) does not have a knock module. Is there one in the ecm? Or is that another clue I have the wrong Memcal?
Old Jul 17, 2011 | 02:46 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The knock filter is mounted on the firewall by the brake booster and relay rack. Thin black plastic square about 3-1/2 x 3-1/2 inches.
RBob.
Old Jul 17, 2011 | 08:19 PM
RBob.
That explains it, thanks!
mrbird
Oct 20, 2015 03:43 AM
tmellott89
Oct 14, 2015 02:06 PM
ULTM8Z
Oct 2, 2015 01:25 PM
Lmancha96
Sep 25, 2015 08:11 PM
HikoriYami
Sep 21, 2015 07:11 PM
