APU1 AutoProm Package and GP1-Now what?
Old Sep 20, 2011 | 08:41 PM
3rd Coast Z's Avatar
Car: 1987 IROC Z / 1999 Suburban 2WD
Engine: Lingenfelter 383 / Vortec 350
Transmission: 700R4 / Built 4L65E
Axle/Gears: Stock / 4.56 Locker
I suppose where I am at now is which file to start out with. Moates has a few bin files but I really don't know how to tell one from another. My car has an old Lingenfelter built 383. It has the accel/lingenfelter intake and edelbrock shorty headers with y pipe. No cats and 3" back to a magnaflow.
This whole thing started with the check engine light. All I wanted to do was get it inspected. Come to find out the MAF had been raped by the previous owner. The thing is the car runs like a champ with the MAF that way. I ordered a new used MAF that had been unmolested and plugged it in. Check engine light went off but the car became undrivable. It would idle a bit rough and as soon as I put it in gear it would die.
Old Sep 20, 2011 | 09:28 PM
gbayfisher's Avatar
Car: 1987 Trans am GTA
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
Re: APU1 AutoProm Package and GP1-Now what?
The bin file is what is actually on the chip, you need the proper adx and xdf file to be able to read what is on your chip using the tuning software.
What Ecm do you have?
Old Sep 21, 2011 | 01:51 AM
165
Old Sep 21, 2011 | 04:49 AM
gbayfisher's Avatar
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
It might be less complicated if you go to Tunerpro instead.
Go to downloads and definitions, there you will see definitiions for different ecm, yours will use $6e and $32/$32b.
Download both the bin definition and also the datastream definition if you want to datalog.
Make sure you read the tutorials in the stickies!
https://www.thirdgen.org/forums/diy-...uide-book.html
Old Sep 21, 2011 | 03:46 PM
Ok, so I downloaded the 32b.xdf and the 165_160.ads. Which I have no idea what either of those mean. Now i need to download one of those 3 bin files on tunerpro?
Old Sep 21, 2011 | 04:21 PM
gbayfisher's Avatar
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
The xdf, is used by tunerpro to read the bin(chip). The ADS is used by tunerpro to datalog to a computer.
You need to open tunerpro, look for XDF on the menu, open, select the XDF file from your comp.
Do you have the ninth injector (cold start injector)
Old Sep 21, 2011 | 04:24 PM
Ok I got the 32b.xdf to open up on tunerpro rt. Is this enough to get the car running? I tried to open a bin file from tunerpro downloads but it does nothing. Do I have to be connected to the car before I can open the bin?
Old Sep 21, 2011 | 04:25 PM
9nth injector, I dont know. Is that something I can physically see?
Old Sep 21, 2011 | 04:44 PM
gbayfisher's Avatar
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
Yes, do a search for the location, you will then know it when you see it.
To save a BIN from the site, right click and "save target as".
Is your chip soldered onto the prom?
Old Sep 21, 2011 | 05:05 PM
Pretty sure there is no ninth injector. There is not an extra line coming off the back of either fuel rail. I have the super ram and I don't think it came with the ninth injector. But I did find some critters nest in the valley under the intake.
I have downloaded the bin from tuner pro website. I have the chip adapter for live emulation.
Well I guess it was soldered in.....but its not anymore. Guess I'll be driving around with a laptop for awhile.
Old Sep 21, 2011 | 05:20 PM
gbayfisher's Avatar
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
Dont always need the laptop, you can run off the autoprom.
Old Sep 21, 2011 | 05:26 PM
Going to take the little ones down to the park real quick like and then when I get back I will try and see if the car will fire.
Old Sep 21, 2011 | 08:20 PM
To late to do anything tonight. I am gonna hit it first thing in the AM and try to get it fired up so I can do some data logging.
Old Sep 26, 2011 | 04:55 PM
I have downloaded both the 6e and 32b bins with their ads files. Still car won't start. TP is saying that the aldl is not reading but that should not keep the car from starting. What am I missing. Help!
Old Sep 26, 2011 | 05:25 PM
gbayfisher's Avatar
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
Yes, it will prevent a startup because you have no bin loaded into the autoprom. Your prom is now by-passed due to the G1.
You need to connect to the Autoprom before doing anything.
Did you hit the 'intialize emulation hardware' button on the tool bar?
Old Sep 26, 2011 | 06:10 PM
Yes, it says that it is emulating. I downloaded the bin to the autoprom. I was just reading on the moates FAQ that I need to plug everything in and then open TP. When I get home I'll try a couple different things. Anymore suggestions are very welcomed. I seem to be tuning handicapped.
Old Sep 26, 2011 | 07:49 PM
gbayfisher's Avatar
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
Its a little confusing to get tunerpro started, once you get it figured out, you won"t have many issues.
Old Sep 26, 2011 | 08:00 PM
Everybody says getting started is the hard part. I'm just ready to be done with the hard part. And of course once again I can't work on it tonight.
Old Sep 26, 2011 | 08:07 PM
gbayfisher's Avatar
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
Go to Tools, preferences, and make sure you have it set up like this:
Attached Thumbnails APU1 AutoProm Package and GP1-Now what?-tp-preferences.jpg
Old Sep 27, 2011 | 07:11 PM
So....I'm an idiot. I finally got the car to start and run like it has been. I forgot a couple minor details when I was installing the GP1 adapter. And THEN I had the OE chip in wrong. wow. Now I need to find a good bin to start with. I'm guessing one of the Corvette bins since I have aluminum heads. Any suggestions? I still can't drive the car with MAF plugged in until I get a better calibration for it.
Old Sep 27, 2011 | 07:29 PM
gbayfisher's Avatar
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
If the car was running okay with the other tune, why not start there?
It may be easier starting with a 'known' bin, make a few changes to see how the engine reacts, and go from there.
Starting from scratch can be very frustrating, leading you to run in circles.
If you decide to start with a new bin, you have to adjust a few things to make it work for initial start up.
Make sure you read every sticky up top to get a grasp of what does what.
Old Sep 27, 2011 | 07:41 PM
Well the only problem with using the tune I have is that the car will barely idle with the MAF plugged in. Unplugged it runs great. Thats how this whole thing started. But I will plug in the MAF and let it run for a minute to see what I can find out. Thanks again.
Old Sep 28, 2011 | 07:05 PM
Old Sep 28, 2011 | 07:08 PM
Now what? I finally get some love out of this thing but this is all she will give. Any ideas why this is happening?
Old Sep 29, 2011 | 07:58 PM
gbayfisher's Avatar
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
I'm not sure what would cause other than a wrong file. I see no rpm's, but is the car running at that moment?
Old Sep 29, 2011 | 08:58 PM
Well, I tried a couple different files today and found one that gave me a bit more data on the dash. But the car still wouldn't start. The TPS was functioning and I believe the temps were reading right but hard to say because the car wasn't actually running.
Also, I did some cross referencing on the chip that is in my ecu. It appears that it is for an 88 firebird 305 with manual tranny. Why on earth one somebody put that in this car?
Lastly, I found a wire cut on one of the pigtails that plug into the ecm. I looking for a pin out diagram now to see what it controls.
Old Sep 29, 2011 | 09:26 PM
Well the wire that is cut should be "M/T od, A/T TCC". Gees, what next?
Old Sep 29, 2011 | 10:53 PM
gbayfisher's Avatar
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
I would re-connect the wire, I don't know why it would have been cut.
You may be better off starting with a new bin.
A close to stock arap bin should start your combo, but you need to know what you have for mods, there are a few things you would need to change for initial start up.
Old Oct 1, 2011 | 06:03 PM
Is it possible that someone may have reprogrammed a OE chip? The id on the chip in my car goes to an 88 5-speed. Mine is an auto. When I downloaded my current bin to tunerpro and checked the prom id it matches an 89 auto vette. I was under the assumption that this couldn't be done but....
Old Oct 2, 2011 | 08:52 AM
gbayfisher's Avatar
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
Take a look at this link here; https://www.thirdgen.org/promintro.
Very good read about chips and such.
It doesn't matter really what chip was used, the auto/manual trans settings are done in the tune. Did you purchase any new flash chips?
What bin are you trying to start the car with?
Old Oct 2, 2011 | 12:20 PM
At this point I am comparing my bin to the ARAP bin in TP to see what differences I see. So far it appears that the timing is the only major difference but even that doesn't seem to be to far off. I was going to try and start the car with my chips bin in TP with emulation but have not been able to get to it.
I do have several extra chips that came with all the Moates stuff.
I'm on lunch so I will go and read up on the link you posted.
Old Oct 5, 2011 | 07:41 PM
So...I have used the apu1 to save my stock bin to my hard drive. But when I load it back to the autoprom to do some live emulation the car won't start. I don't understand what the difference is. I assume I am using the right def and datastream because I am getting good data from the ALDL. Still can't get the car to start with any other bins.
Old Oct 5, 2011 | 07:53 PM
gbayfisher's Avatar
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
If you have had the car running with this bin, It should work to start the car.
Is you cable from ap1 to the ecm on in the correct direction? It will go on the wrong way, causing a no start, or limp home mode.
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
jrdturbo
Mar 31, 2016 02:58 PM
tmellott89
Oct 14, 2015 02:06 PM
Dragonsys
Sep 25, 2015 03:51 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
