reading out bin on chips
Old Oct 15, 2011 | 07:29 AM
lakeffect2's Avatar
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
I have a Prominator hooked up on the ol' beast. If you are familiar with them, they can store eight different programs or bins/burns which are switch selectable.
One bin in particular works well at solving some issues I've had , but do to keeping bad notes on the matter, I can't remember what bin (burn) I loaded into position #4.
I have no clue if I can reverse the process to read what burn is in the chip at that position. I can datalog, but I don't see anything in the log that tells me which burn I'm recording, much less the settings that created it.
I'm using Tunerpro V4 at this point.
Any insight would be most appreciated.
Dave Buchholz
Rochester NY
Old Oct 15, 2011 | 09:07 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: reading out bin on chips
Apparently the Prominator software won't allow the user to read out a BIN. However, there is a verify function. Use that on each BIN you have to see if you can find that one that matches what is in the Prominator.
To keep track of BINs I use and recommend that the tuner use the PROMID value in the calibration.
RBob.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
ambainb
Aug 29, 2015 12:43 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
NWAsonoma
Aug 18, 2015 05:45 PM
