TunerPro 5 dash
Old Nov 26, 2011 | 02:27 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
TunerPro 5 dash
I wanted to do a cold start data log with Tuner Pro 5 today. When I open TP to the dash screens they are all blank and when I try to connect TP to the aldl cable nothing happens, it doesn't even attempt to connect?? The computer battery died yesterday so I'm not sure if that effected anything? Thanks
Old Nov 26, 2011 | 06:23 PM
Car: 89 Formula 350
Re: TunerPro 5 dash
data log screens are still blank. It looks like if I try to play a previous data log it is playing, meaning I can see the log bar graph moving at the top of the screen and it shows the name of the log. It also gets the Blue playing log box at the bottom of the screen but no info from the log shows up in the dash or any other data log info area???
Old Nov 26, 2011 | 06:54 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: TunerPro 5 dash
Have you tried setting the gauges to a parameter?
Old Nov 26, 2011 | 08:50 PM
Car: 89 Formula 350
Re: TunerPro 5 dash
have no idea what you mean, sorry not a big computer guy.
I sent Mangus a PM and he suggested this??
"Have you tried posting in the DIY-PROM board? If not, please do so. You probably need to reload your datastream definition (the ADS or ADX file) for your vehicle"
not sure how to do this, my car is an 89 6E 1227165. If someone could talk me through this step by step?.thanks for any help guys.
Old Nov 26, 2011 | 11:16 PM
Re: TunerPro 5 dash
Reloading your ADS or ADX would be in other words opening the ADS or ADX file again, just like you did to load it the first time.
You can change each gauge's parameters by right clicking on each gauge and selecting what you want to display.
Old Nov 27, 2011 | 12:19 AM
Car: 89 Formula 350
Re: TunerPro 5 dash
have no idea how that was done, its been a long time
looks like this guy had the same issue, not really following how he corrected it.
https://www.thirdgen.org/forums/diy-...rov5-will.html
Old Nov 27, 2011 | 01:27 AM
Car: 89 Formula 350
Re: TunerPro 5 dash
ok, I reloaded my definition and its working again thanks guys!!
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Fanatic1074
Oct 2, 2015 03:47 PM
ULTM8Z
Oct 2, 2015 01:25 PM
lewandom
Oct 1, 2015 08:15 AM
