How to make a 2 BAR MAP work with a GM 8D #1227727 ECM?
Old Dec 14, 2011 | 04:24 PM
Flame Red's Avatar
Hi Folks,
First post. Hope I posted this is the right forum. I tried searching and goggling for help on this but my extensive efforts were not fruitful.
I have a L98 350 TPI from a 90 Vette running the stock vette 8D ECM with a Procharger 600b. I am a novice tuner so please take that into consideration when you explain this to me.
I was advised that I could get a better tune if I used a 2 BAR MAP instead of the stock 1 BAR MAP. I purchased a 2 BAR MAP for a 87 Buick GNX, and cut the key ways so I could plug the MAP into the stock connector.
Some of the posts I found said others have switched to 2 BAR maps in "similar" GM ECM's by just halving the values VE to MAP table. I tried cutting my current VE to MAP table by 1/2 but the car will not start or run when I install the 2 BAR MAP. So I assume there are more changes needed. It kind of shuddered. Reinstalling the stock 1 bar MAP and the car runs good.
I was hoping someone could guide me on how to get the #1227727 ECM to work with a 2 BAR MAP. What values need to be tweaked?
Or is it impossible?
Thank you in advance.
Old Dec 14, 2011 | 04:38 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: How to make a 2 BAR MAP work with a GM 8D #1227727 ECM?
you can run a code$58 or $59 www.code59.org
Old Dec 14, 2011 | 04:43 PM
Engine: Lb9
Transmission: M20
you also might want to look at dynamicefi.com they have a ebl p4 flash for the 1227727
Old Dec 14, 2011 | 06:40 PM
Flame Red's Avatar
Originally Posted by tunedperformanc
you can run a code $59 www.code59.org
I tried to register, but it won't send out an email confirmation and I cannot see the download areas.
That is an interesting possibility, but I see this note:
5) '90 - '91 Corvette owners: the EBL P4 ECM will not communicate with the CIM. If there is enough interest this functionality may be added in the future.
I have heard of a CCM but what is a CIM? Is that the (digital) dash?
Old Dec 14, 2011 | 06:53 PM
Engine: Lb9
Transmission: M20
Communication Interface Module ? All I see is a CCM , email user rbob !Name:  90-7727V8TPI-7.jpg
Old Dec 14, 2011 | 10:36 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
You will have the same problem trying to use $58 or $59. There is nothing in that code to connect with the CCM/CIM/BCM/Wheteverit'scalled.
I replied to this on Tunerpro.net as well, but with more info.
Did you check your spam folder? Sometimes the e-mails from the site get treated like spam.
Old Dec 16, 2011 | 07:34 AM
Flame Red's Avatar
Anyone have any tips on using a GM cyclone/typhone mask in a 727/730 ECM?
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
customblackbird
Oct 1, 2015 04:30 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
gta892000
Sep 16, 2015 12:40 AM
