which zif socket to use?
Old Jan 8, 2012 | 06:32 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Hello guys. I almost had a life threatening incident. I was close to bending the heck out of my EPROM when I was installing it inside the Moates G1 board. So my question is, which zif socket should I use inside my 7165 ECM?
1. Low Profile = http://www.moates.net/s4-aries-28pin....html?cPath=26
2. Bulky socket = http://www.moates.net/s2-aries-28pin....html?cPath=26
Is there any soldering involved?
Old Jan 8, 2012 | 09:15 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: which zif socket to use?
Either ZIF socket will work. I opted for the "bulky version" because I have read a few complaints about the EPROM not holding as well in the low profile version.
No, no soldering needed, it will plug directly into the DIP socket of your adapter.
Old Jan 8, 2012 | 09:28 PM
Cool. So with the bulky zif socket, is there still enough room to screw down the ECMs dust cover?
Old Jan 8, 2012 | 11:49 PM
Not usually.
Old Jan 9, 2012 | 12:41 AM
Damb. I'll just cut up some of my kids bike tires and make an elevated gasket.
Old Jan 9, 2012 | 02:21 PM
Ronny's Avatar
I had connectivity issues when using a ZIF. Stiff suspension. It was not soldered but not sure if that would have helped. RadioS sells a neat insertion tool.
Old Jan 9, 2012 | 02:45 PM
Do you recall what that insertion tool is called? DOnt wanna bend the pins on my chips.
Old Jan 9, 2012 | 02:47 PM
Ronny's Avatar
no not really "eprom insertion tool" ? I picked up at local RS dealer.
Old Jan 9, 2012 | 07:43 PM
I have ran vehicles for a few years with ZIF sockets, without issue.
Old Jan 9, 2012 | 09:04 PM
So then this one would work just as much as good as the Moates one correct?
Old Jan 10, 2012 | 09:45 AM
Ronny's Avatar
I recall my Moates had beefier pins.
My innsue with connectivity may be due to Z51 suspension and the roads(RR tracks) near my house.
Old Jan 11, 2012 | 06:33 AM
elesone's Avatar
Besides, I like to support the products (Moates & TunerPro) supplied by the people that makes this forum so great. The service and support are second to none.
Old Jan 11, 2012 | 02:17 PM
The_Punisher454's Avatar
Car: '74 Firebird, '84 vette
Engine: 454 twin turbo, 350 HSR
Transmission: 4L80E, 700R4
Axle/Gears: 9", Dana36
I've had a few different types of zif sockets, and can say that the "Textool" type above, while bulky is very strong and grips the pins pretty tightly.
I havent run a zif in a car very much, so I've never had a problem.
Old Jan 11, 2012 | 06:05 PM
Where you able to put the ECMs dust cover back on or is the profile too high?
Old Jan 11, 2012 | 06:24 PM
Probably too high. I dont use the adaptor boards like most do. I currently use a low profile socket soldered directly into a memcal. This clears easily. This is one is for tuning, I solder the sf512 flash chips directly to the memcal's for permanent installations or when tuning will be only done occasionally. In this case I have a simple adaptor to plug the whole memcal into my burner instead of removing the chip.
When I used the textool type it was a 40pin version on an older homemade adapter using a very high capacity flash chip from a computer motherboard, custom stuff and does not apply. It was simply a comment on the ruggedness of the textool type zif socket.
Old Jan 11, 2012 | 07:29 PM
skiroulertx447's Avatar
Car: 86 Z28
Axle/Gears: 3.42 posi
when I had the big adapter on my car the little cover wouldn't fit, but I need more tuning so the computer is still laying on the floor.
Old Jan 11, 2012 | 10:57 PM
WOW!!! A 1986 Z28 owner!!!!! I always see 86 Berlinettas, 86 IROC's, but never a 86 Z28. Right on man.
Old Jan 11, 2012 | 11:25 PM
Car: 86 Z28
Thanks!!! I have seen a few other 86 Z28's in MN, most of the thirdgens I see are just base models though.
Old Jan 19, 2012 | 11:50 PM
Similar to this one right? this is the only one I saw at my local RadioShack......
Old Jan 20, 2012 | 01:34 PM
Ronny's Avatar
That is not a ZIF nor the "tool". It is a plain socket 30 pin.
Old Jan 20, 2012 | 02:39 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
personally, i've only ever had 1 instance of the PROM moving around in the ZIF while driving and causing the ECM to go into limp-mode.
i also use 7727 type underhood ECMs, so the bulky one worked perfectly fine for me on top of my G3.
Old Jan 21, 2012 | 09:49 AM
EagleMark's Avatar
No! Moates sells good parts that are tested in cars. Even if you can save a buck, really one buck why would you even try?
Buy from Moates and keep them in business so they can keep developing products that tuners need and want.
Old Jan 21, 2012 | 10:26 AM
Ok! Got the Aries zif. Gonna have to mod a elevated spacer for my ECM today. Thanks for the input fellow members.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Fronzizzle
Feb 9, 2017 09:31 AM
Fox118
Members Firebirds
111
Jan 26, 2016 07:17 PM
ramicio
Sep 28, 2015 01:18 PM
roysatikas
Sep 22, 2015 08:15 PM
