2 simple questions then I'm ready to get started! Please Help!
Old Jan 9, 2012 | 07:38 PM
Blade09's Avatar
Car: '91 RS / '17 FiST
Engine: Internal cumbustion
Transmission: 1 with a fun pedal and 1 without
Axle/Gears: 4th gen ss
Sorry to waste people's time but I have what I hope are just 2 simple questions keeping me from getting into tuning.
1st, is there a way to figure out exactly what ECM I have? I bought a complete TPI setup that I believe is out of an '89 trans am but I checked the numbers on it and they are the same for '86 - '89 but they have different masks. What can I do to make sure it is an '89? This is critical because I am swapping my stock 305 tbi for a mildly built 350 tpi and I want it tuned in.
2nd, I did my best to read everything before I started asking questions but I have to. I understand the components that I need for the process but the part #'s in the Prom burning Guide are way out of date. Could someone recommend a quality economic Programmer? I want whatever I need but I'm more or less a poor college student (thankfully a computer engineer/computer science double major )
Any help or info would be greatly appreciated!
Thanks,
Blade
Old Jan 9, 2012 | 07:53 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 2 simple questions then I'm ready to get started! Please Help!
Open the ECM's small cover. In the MEMCAL, on the PROM will be a silver label with a 3 or 4 LETTER code. Post back what it is.
For logging/burning: www.moates.net:
G1 adapter
Burn2
27SF512 Flash Proms
An ALDL cable (USB or Serial dependent upon your laptop)
www.tunerpro.net:
Download Tuner Pro RT
RBob.
Old Jan 9, 2012 | 07:54 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
http://www.moates.net/burn2-chip-pro....html?cPath=64
this is the programmer i just got, great item and support, very easy to use.
http://www.moates.net/gp1-package-gm....html?cPath=64
Heres the chips and adapters i also just got.
http://aldlcables.com/sc/details.asp?item=aldlobd1u
Here is the ALDL cable i have, you need this to data log(connect your laptop to the car)
Thats all you need to burn chips and data log , else then the free software, your files and such that are free also. And of course a lap top if you plan to datalog. Its a little bit of $$ but it worth it and works good for me.
Im a poor college student too!!! Im in Heat, vent, A/C (HAVC) program. I wish i was better at computers.....
I have no idea about your ECU situation though, someone will chime in and let ya know whats up with that...
Old Jan 9, 2012 | 07:55 PM
fasteddi's Avatar
Car: 1991 Camaro RS
opps RBob beat me to the post, at least the responce about the hardware... sorry about that.
Old Jan 9, 2012 | 09:15 PM
Blade09's Avatar
Thank you sir, and Rbob as well. My dad is checking the ECU for me (its at my house still) and I'll post up the code for ya as soon as I get it from him.
Old Jan 9, 2012 | 09:21 PM
Blade09's Avatar
Rbob: He said it read "Delco ACXU 1104" on the silver tag
Old Jan 10, 2012 | 08:08 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
That is for an '87 Firebird, LB9 (5.0l), auto, 2.73 rear, Cali emissions
RBob.
Old Jan 10, 2012 | 08:49 AM
Blade09's Avatar
RBob.
That's less exciting than I was expecting
Looks like it was a good thing I checked cause I'm definitely going to need a retune. Thanks Rbob!
Old Apr 15, 2012 | 04:18 PM
Blade09's Avatar
Sorry to revive an old thread but I was rereading it now that I can actually afford to tune the poor car and I have one more question that I didn't notice before.
Rbob, and fasteddi suggested basically the same equipment (which I greatly appreciate) but fast also said he's using the g1 adapter and ZIF socket.
My question is, do I need the zif or is it something for other applications? Any info would be greatly appreciated.
Old Apr 15, 2012 | 06:35 PM
fasteddi's Avatar
Car: 1991 Camaro RS
The zif socket is to let you easily remove the chip. Basically take in in and out as you want, insted of actally soldering the chip.
Frozer!!!
Jan 19, 2024 04:55 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
