WB input to pin on 7730 ecu
Old Feb 9, 2012 | 08:19 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Ive searched but this is a hazy answer as ive seen many answers.
What pin should I connect my linear 5v output of my SLC controler to in the ECU?? Im running a $59 mask that has the wideband input on it.
Thanks for any advice. I did see a few times that the AC pin works.. The C21 pin?? Would that work, as my A/C has been removed.
Old Feb 10, 2012 | 12:07 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: WB input to pin on 7730 ecu
There is a great thread that explains exactly which pin to use with $59 on the code59 site.
Old Feb 10, 2012 | 06:31 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Ill look again but i sure didnt see it. Ive seen hook it to F14 and others, the one thread i found on code59 says... page no longer found...There is alot of threads/links like that on that site.
I connect the 0-5v output to either pin A3 or F14 on the 730 ECM
Ive found this a few times on TGO, and what i read is that F14 is for the 7730 ecu, so I will try that pin and hope i dont mess anything up.
Old Feb 11, 2012 | 12:55 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I'm not sure where the $59 states to put it.
On the 730 there have been a few reports of problems on A3.
F14 seems to always work. (Hopefully that is the pin assigned in the 59 code.
InfernalVortex
Apr 20, 2021 11:31 AM
cheesehomer
Dec 31, 2015 08:48 AM
KO1
16
Oct 15, 2015 05:00 PM
Linson
Oct 1, 2015 09:50 PM
