Moates.net chip?
Old Apr 9, 2012 | 05:44 PM
camarojuggalo's Avatar
Car: 1987 Iroc-z
Axle/Gears: 3.73 posi
Moates.net chip?
Just bought a camaro and was looking around in the car open the computer and seen that there is a moates.net memory adapter and chip in it. What does it do and why is it in there (new to the prom thing) any info would be helpful
Old Apr 9, 2012 | 06:51 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Re: Moates.net chip?
Moates makes hardware so you can burn a custom chip
Old Apr 9, 2012 | 08:45 PM
Car: 1987 Iroc-z
I guess I got some reading to do cause I know nuttin about buring chips is there a way for me to know what the po put on the chip
Old Apr 10, 2012 | 02:20 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The only way to know would be to read the eprom and hopefully the scan id has been left the same and do a reverse bcc search to identify the original bcc and do a program .bin compare. I would guess its to remove vats maybe egr or changes made for a cam swap or change of definition.
Old Apr 10, 2012 | 09:19 AM
Ronny's Avatar
How does the car run? I would presume prior got it right if runs well.
A datalog (winALDL) would tell you if fueling is accurrate.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
