Tunerpro v5 issues
Subscribe
Apr 22, 2012 | 11:02 PM
I just got v5 and took awhile to get it working. It works and reads the right values, but every 5 or ten seconds the values go to the values as if the cable wasn't connected for a millesecond. When using winaldl I don't have that interruption. Anyone know what could be causing this?
This is on my 86 Z28 using a 89 $6e tune.
Reply 0
Apr 23, 2012 | 01:19 AM
Re: Tunerpro v5 issues
Try Disconnecting and reconnecting in tunerpro from the drop down menu that says accquistiong, or control plus the f4 button.
Reply 0
Apr 23, 2012 | 05:29 PM
You need to use a resistor on the cable to put it into 8192 ALDL mode. Search for that and you'll find all about it.
Reply 0
Apr 24, 2012 | 04:26 PM
My cable has a jumper setup on it that I believe uses a resistor. It works with winaldl.
Reply 0
Apr 25, 2012 | 07:06 AM
Almost every ads file imported to TunerPro RT V5 adx file has needed a pause or an extra byte in reply or both.
http://www.gearhead-efi.com/Fuel-Inj...p-Glitch-in-V5
Reply 0
Apr 25, 2012 | 03:14 PM
Quote: Almost every ads file imported to TunerPro RT V5 adx file has needed a pause or an extra byte in reply or both.
I looked at the link but don't understand it that well. The example they show is for a 7730 and has different commands
Reply 0
Apr 25, 2012 | 04:19 PM
Check your inbox skiroulertx447
Reply 0
Apr 26, 2012 | 12:26 AM
Problem solved. Added a pause for him on the adx. Enjoy buddy.
Reply 0
Apr 26, 2012 | 12:35 AM
Thanks again!
Reply 0
Apr 26, 2012 | 12:59 AM
NP
Reply 0
May 8, 2012 | 04:36 PM
Hey was wondering if you guys could help me out too? im having the same issue with the errors every couple of seconds. I really dont understand where to add the pause to fix it.
Reply 0
Subscribe
