85 vette - 870 ecm question
Old May 19, 2012 | 07:55 PM
racetoday's Avatar
As per the schematic, what we know about the Injectors on an 85 ECM is that the injectors are activated by grounding each bank seperately via solid state ecm activation. Each bank has its own driver output from the ecm for this. In otherwords Batch Bank fire.
What I do not know.... do the drivers activate each bank at the exact same time or does each bank fire at different times. I think just because there is a seperate driver for each bank, it doesn't necessaily mean they fire at a different time, hence this is what I am trying to find out.
Does anybody know "definitively" how the 85 ecm works ?
Thanks.
Old May 19, 2012 | 08:27 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 85 vette - 870 ecm question
Thanks.
According to the schematics that Ludis put together, it is batch fire. All eight injectors fire at the same time. I have no reason to doubt the work Ludis did.
RBob.
Old May 19, 2012 | 09:14 PM
racetoday's Avatar
I do not understand. The schematic I have shows the ECM has two different driver outputs for the injectors. One for each side of the motor. (1,3,5 & 7 and 2,4,6 & 8)
Maybe he has a comprehensive internal ECM schematic ? Would love to see the logic that closes these ECM outputs. They may both be at the same time, but would like to see the on-paper logic that shows this.
Old May 20, 2012 | 08:57 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
www.exatorq.com/ludis_obd1/schematics.html
See the 1227170 ECM, same hardware. You're welcome.
RBob.
Old May 20, 2012 | 05:08 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
a lot(and by that, i mean all) of the 60V6 MPFI applications are setup the same way... 1 driver controls 2 pins.
Old May 21, 2012 | 11:59 AM
racetoday's Avatar
Okay... thanks guys.
Old May 21, 2012 | 12:59 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Some time ago I lost a bet on that one, the '870 TPI ECM along with the MAF 60V6 MPFI ECMs ('7302) have two injector drivers. Just that they are fired together. Check out the schematics I linked too, they are handy to have.
RBob.
Old May 21, 2012 | 01:10 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
gah, other than the fiero, i forgot there were even any 60V6 MPFI applications that were C3. for some reason i thought the 2.8 F-bodies used a 7730 or similar.
http://www.exatorq.com/ludis_obd1/1227170sheet6.gif
i see it, 1 actual control circuit controlling a chain of transistors... i guess it would be more accurate to say that it's using a single injector "channel" to control all of the injectors.
Old May 21, 2012 | 01:21 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Only the '90-'92 3.1l f-body cars used the '7730.
RBob.
Azrael91966669
25
Jun 20, 2017 04:04 AM
hokis
Wheels and Tires
Aug 26, 2015 04:21 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
