ANYX bcc hard to find?
I've looked everywhere and searched 3go for the ANYX bin with no success. It apparently is very rare.
This bin is for a 1989 5.0 5 speed with the G92 optional 3:45 gear ratio.
I figured I could simply use APYS and change the gear ratio or VSS.
I can't see anywhere to change gear ratio or VSS in the bin using tunerpro and $6E extended.
Does anyone know how to change the ratio without using code? Thanks.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: ANYX bcc hard to find?
There are two 16133478 still available through gm's discontinued parts supplier. the $6e does not use a ip divisor not sure what your trying todo.
Thanks. The prom part number is 16133630 but I'm not looking to buy a Memcal and I realize there is no IP divisor.
All of the available bin files for the 1989 5.0 with 5 speed are for the 3:08 gear ratio.
The ANYX BCC is the only one for that car with a 3:45 gearing.
Because they are different and the only difference is the rear gear ratio in these bins, I was wondering if there was a way to change it in the basic code.
The question is, if it doesn't matter what the gearing is and can't be changed why would there be a different BCC for the G92 option and why would it be so rare that it is not listed in any of the bin libraries?
Probably not many G92 optioned cars sold but there should still be bins around I would think.
I would really like to compare these bin files to see the differences but I can't seem to locate one.
Engine: LO5 350 (TBI 220)
Transmission: 200R4
A few people here claim to have one:
https://www.thirdgen.org/forums/diy-...ual-89-6e.html
https://www.thirdgen.org/forums/diy-...-anyx-bin.html
etc. You might try contacting them.
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
Any chance you could post that bin? I to was looking for one to replace my 88 ($32b) LB9/T5/3.45 optioned GTA that has a AKFY bin
ambainb
Apr 25, 2016 09:21 PM
lt1z350
Sep 29, 2015 01:50 PM
mcquigg
Aug 13, 2015 02:26 PM
