Roller rockers causing knock counts?
Old Jun 24, 2012 | 10:49 PM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Has anyone experiance knock related to roller rockers? I am having knock counts and timing retard that doesn't seem to have a logica source. It seems to occure in a 1200-1800rpm range regardless of load (LV8~ 156 $6E-MAF) The rockers I am using have a noticable "mechanical" sound which is more noticable at this rpm range. Any thoughts or comments?
Old Jun 25, 2012 | 08:10 AM
7thdarkangel's Avatar
Car: 1983 Camaro
Engine: Missing
Transmission: Missing
Axle/Gears: 9" Ford
Re: Roller rockers causing knock counts?
Are they seated and tightend properly? i just finish building my new engine had them seated real nice broke the engine in for about 20 min and now im going back in to re adjust them.
Old Jun 25, 2012 | 07:49 PM
Car: 89 IROC
Engine: 6.8 HSR N2O
yeah I don't have a lot of miles yet but pulled a cover and re-adjusted that side and they were spot on. Still a lot of "noise" associated with them but definatly no lash.
Old Jun 25, 2012 | 08:26 PM
87SLEEPER's Avatar
Car: 1992 RS B4C
Axle/Gears: 3.23 10 bolt limited slip
were they noisey? I am in a similar situation with approx. 20 mins run time for break in and I hear a noise coming from the #8 cylinder.
Old Jun 26, 2012 | 07:07 AM
Car: 89 IROC
Engine: 6.8 HSR N2O
I don't know how "noisey" I'd call them. Not a "tic" like they need adjustment and not like a solid lift cam. More like rattley. If you remember the sound an old-time roller skate wheel would make when you spin it- that would be the closest I could explain. The sound of an open ball bearing. It's about the same decible level as the injectors make. When I close the hood you can't hear them but it's just loud enough to notice when driving by a highway barrier or wall. And just enough in my opinion to ask the original question.
Has anyone else seen knock retard that they attributed to the roller rockers? This "rocker" discussion is great but not the core issue of my thread.
Old Jun 26, 2012 | 09:18 AM
LastC3's Avatar
Engine: 355 cu in CFI
Transmission: 700 R4
Axle/Gears: 355
Have not had any issues with my roller rockers relating to Knock .... If you confirm it is the rockers causing your issue, I would certainly look into the type and condition of your rockers .....
Are they full roller, or roller tips ???? I've heard of issues with the roller tip rockers .....
Old Jun 26, 2012 | 10:10 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I've used Crane aluminum full roller rockers, Comp Cams steel full roller rockers, and Comp Cams cast roller tip rockers with no issues with the knock sensor. These were all on hydraulic flat tappet cams.
If you used Comp Cam 853 lifters (hydraulic roller) that is most likely where the noise is coming from.
RBob.
Old Jun 26, 2012 | 11:14 AM
Car: 89 IROC
Engine: 6.8 HSR N2O
Thanks guys. These are full-SST roller rockers. The "no-name" brand from Skip Whites. They are brand new with maybe 100 miles, if that. They seem to be of decent quality and no, I have not linked them to my knock retard issue just yet. Pretty much a suspicion I was hoping to rule out. Thanks for the replies and I will let you know when I learn more.
So far I have pulled a lot of timing out in the low rpm/lv8 ranges. This is where I get most of the timing retard. I am now dumping more AE in to see if that may be a part of the problem. This is a 165/MAF car with a TKO 5-speed/3.70 gear. Spends a lot of time in the 1200-2500rpm range when crusing in 5th and is kpet there due to the stick shift application.
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
