IAC behavior question
Old Jul 11, 2012 | 06:22 PM
KurtAKX's Avatar
Car: Pontiac
Axle/Gears: 3.08 / Drums
sanity check-
when you short out the ALDL and the ECM runs the IAC down to zero counts, should the plunger be run all the way in (towards the IAC motor body) or should it run out (away from the IAC motor)????
Old Jul 11, 2012 | 09:02 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Re: IAC behavior question
Originally Posted by KurtAKX
sanity check-
it should run away from the iac motor, so if the iac was out of the t body
it would shoot across the room
Old Jul 11, 2012 | 09:36 PM
KurtAKX's Avatar
Car: Pontiac
That's what I thought- my stupid IAC adapter must be wired backwards!
Old Jul 12, 2012 | 07:46 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
If it is stepping in, just swap the two wires on one of the coils. That is all that is required to make it step out.
RBob.
bamaboy0323
Sep 3, 2015 06:07 AM
86IROC112
Aug 21, 2015 07:20 PM
86IROC112
Aug 21, 2015 12:39 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
