AE lookup based on time Q? EBL.bin
Old Aug 22, 2012 | 10:59 AM
Ronny's Avatar
I am trying to ascertain which value(s) the ECU uses for time when an AE event occurs.
Lets say I move the TPS % as fast as humanly possible. .001 msec. I go from cruise at 13% tps 48 map 30 mph TO 33% tps 80 map same mph.
I suspect it will then use the AE TPS PW look up for 20% AND the AE MAP at lookup of 32 MAP. Adding in a sum total of AE from both tables. Then modified for RPM AE + coolant + filter. My filter is same for TPS/MAP at operating temps.
Then the Q is what time frame would modify that change. Lets say I am entering Xway and do a typical roll on of TPS%. AE is "on" yet it must use a period of successive bits of time. Is it 100 milliseconds(.1 sec) or 50 msec etc?
I am attempting to tune my AE at the RPMs > 2400. It seems I need little to none. I am pulling 30% at 2400 rpms and 73% at 4800. My AE TPS and AE MAP are somewhat flat in values. In fact I have more usec at lower TPS% than higher(600 3% dropping to 427). Map low kpa is 305 0 kpa rising to 427.
75 lbs injs at 26 lbs FP.
It seems an AE event could use possibly 5 differing positions on each table or more?
Old Aug 22, 2012 | 11:49 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: AE lookup based on time Q? EBL.bin
No to the filtering of the PW. The filter values are used to create the delta TPS & delta MAP values. The dMAP & dTPS values are used to 'look up' the AE PW from the respective table.
RBob.
Old Aug 22, 2012 | 11:53 AM
Ronny's Avatar
Was my assumtions on the other correct?
Old Aug 22, 2012 | 12:02 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The TPS is filtered every 25 msec (40 Hz), with the MAP filtered every 100 msec (10 Hz).
This creates a lagged value that is subtracted from the current TPS/MAP to create the delta.
Lots of info in this thread:
https://www.thirdgen.org/techbb2/sho...hreadid=249265
RBob.
Vintageracer
Jan 10, 2020 05:33 PM
z28_AJ
Aug 27, 2015 08:59 PM
eddie jr
Aug 25, 2015 06:52 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
