Use of O2 R/L tables in 6E MAF systems
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
After re-reading the stickies on the 730 O2 constants and RBob's ECM Proportional Control from '02 (awesome write up dude!) I am still plagued by a delima on my 6E MAF system.
To bring you up to speed here...
You can look at my sig but it's an aluminum headed L98 with a mild cam (212/218) HSR intake etc. I am using TunerPro v5 and have an Innovate WBO2 gauge with the WB output in my data logs. I am working with the expectation that my WB readings are correct at idle. Stoich AFR is set @ 14.7 and I am running 10% alcohol fuel. I have been adjusting my O2 R/L mean, upper and lower tables to bring my idle AFR to ~14.7 to 15. Currently my mean O2 R/L is 635 at idle with upper/lower +/-35. 14.7 on the WB gauge is where my engine pulls the most vacuum @ 16hg. Idle speed is 650. I have been able to get the idle AFR perfect when up to full temp and BLM's are 128ish. After idling for about 4-5 minutes the BLM's start to drop to 118 and AFR jumps up to <16. It seems to stablize there but vac drops to 15hg and it runs less smoothly.
My question is "Why does the ecm start pulling fuel after idling for a while?" I suspect it is somewhere in my other settings like the reduction gains or filters but can't seem to get a handle on it. My gut call is that something is getting into a runaway situation mathmatically. Any suggestions on what to adjust will be greatly appreciated.
BTW I have deleted my EGR and AIR and have made the necessary changes in the bin.
Car: check
Engine: check
Transmission: check
Re: Use of O2 R/L tables in 6E MAF systems
Check the O2 signal, that is what the ECM will follow. I like to graph it along with RPM to get a better idea of what it is doing.
When an O2 sensor cools off it tends to report lean, which forces the BLM high. A silicone poisoned sensor reports rich driving the BLM down.
With the headers need to use a heated O2 sensor. If the tip of the sensor has a white almost fluffy substance on it that is silicone.
RBob.
RBob.
Car: 89 IROC
Engine: 6.8 HSR N2O
RBob.
RBob.
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Antman,
ever figure out what was the problem here?
Car: 89 IROC
Engine: 6.8 HSR N2O
Not really, I ended up building a different motor and running the EBL flash ecm. Now with a longer duration cam (and larger ci) I still have had a difficult time with closed loop. I run open loop during idle and closed loop at cruise with the PID dummed down some. I also bracket the BLM so it can't adjust farther than 120/136, which it does stay between. Don't know if that helps but it's what I've done.
db057
08-11-2015 10:11 PM
