Best option for boosted 7730
Wow first post after all this time...anyways I've got a 355 L98 With .030 over flat top pistons, Vortec Heads, Lt1 stock (1995 fbody) cam, Weiand Vortec Stealth Ram, 24# injectors, adjustable fuel pressure regulator (holley fuel rail kit) all attached to a t56 in my 95 firebird. I'm running a 7730 SD ecm with a custom aujp chip from v6 ecm setup for stock tpi 350. I bought it off ebay and it runs good lacks full power but its still pretty fast and no check engine light (BTW it works...and aldl is in stock location)
I want to put a t70 remote turbo on the back and run about 10 pounds using fmu to assist, i know the $8D code wont reference boost so what would be the best way to go about keeping the 7730 and pinout and running this turbo setup $59 or what...thanks for the help
gixxer92
May 18, 2017 11:20 AM
Dragonsys
Sep 25, 2015 03:51 PM
