O2 voltage
Old Feb 11, 2013 | 12:05 AM
petrolhead's Avatar
Car: '83 trans am Lear Siegler
O2 voltage
I was wondering where the o2 voltage should be in pe mode. I'm using the ebl flash, but I do not have a wb o2. Its hard to get a ve learn in under acceleration, but my o2 is steady around 750 during pe. Is this too rich?
Also, what does launch and async do?
Old Feb 11, 2013 | 02:30 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Re: O2 voltage
You might want to wait for others to chime in. But I always was told it should be around 900.
Old Feb 11, 2013 | 10:32 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: O2 voltage
Launch mode adds spark advance to get the engine up against the converter and move out. Or in the case of a stick shift, just to get the car to move out. Notice how it is only active for a short period of time and under a certain MPH.
Async is when the injectors fire together every 12.5 milli-seconds. That is, asynchronously to the spark plug firings.
I too would shoot for a higher O2 in PE mode.
RBob.
Old Feb 11, 2013 | 10:36 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: O2 voltage
Same here, 900mv is what it's supposed to be according to some guys on here. On a side note, atleast being richer is better than lean in WOT.
Also, here was a discussion on this: https://www.thirdgen.org/forums/dfi-...sensor-mv.html
Bottom line is that a NB O2 doesn't read accurately before and after 300mv and 700mv respectively.
Old Feb 14, 2013 | 02:38 PM
petrolhead's Avatar
Re: O2 voltage
Thanks all of you, looks like I'll be turning it up a bit for now. A wb will be in the future, after some engine work is done.
Elephantismo
Feb 13, 2019 12:51 AM
327IROC85
Sep 23, 2015 12:11 AM
eustodp
Sep 20, 2015 05:09 PM
ULTM8Z
Sep 16, 2015 09:15 AM
RyanJB
Sep 2, 2015 01:27 PM
