NEWB reading chip & getting it into tunerpro
Old Apr 19, 2013 | 10:15 AM
greggbruce's Avatar
Car: 84 454 monte, 89 formula, 86 camaro
Engine: the bigger the better
Transmission: 700/4L60 in everything
Axle/Gears: wish they were all 4.10's or better
ok, I have read flash & burn pdf, got the adapter for my factory memcal, hooked it up, read the chip, saved it to file, and I can look at it in the editor of flash and burn, but after loading the proper xdf into tunerpro ($32b), when I open the bin from the file I just saved and open any values or look at tables, they all show 0 (zero) --- what am I doing wrong?
Old Apr 19, 2013 | 10:34 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: NEWB reading chip & getting it into tunerpro
sounds like a bad read you can see it in the buffer before you save it. I assume this is a 87-88 Tpi maf car, if thats the case do the read as a 27c128 if that doesnt work check the address you are reading.
Old Apr 19, 2013 | 10:49 AM
greggbruce's Avatar
yep, set it as a 27c128 -- it shows the chip address as 000000 to 003FFF, is this correct? the flash n burn pdf doesn't show a 27c128 -- it only shows AT29C256 and the 27SF512 and their addresses
I just tried it with my '89 tpi chip ($6E) too, same thing
Old Apr 19, 2013 | 11:09 AM
Engine: Lb9
Transmission: M20
That is the correct address, are you seeing the hex in the buffer ?
Old Apr 19, 2013 | 12:11 PM
greggbruce's Avatar
that was it !!! got it figured out, it doesn't set the buffer addressing fields like it does for the chip addressing fields when you select from the list of supported chips.
THANKS !!!
GTAman
Sep 21, 2015 09:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
NWAsonoma
Aug 18, 2015 05:45 PM
tmellott89
Aug 16, 2015 02:58 PM
