TunerPro Newbie need some help
Old Apr 28, 2013 | 11:06 AM
2012sergen11's Avatar
Car: 1987 Trans Am
Hello,
I downloaded the TunerPro software off moates.net after reading and researching A LOT on this forum. I downloaded the 6e mask bin .xdf file off of the moates.net resources just to open it and see what the software looks like and how it is formatted. When I opened the bin and looked almost all the values were set at zero's.
Does anyone know if this means there is a problem with the way I am reading in the .xdf file or are these files supposed to be set at zero to begin tuning the chip from the ground up?
Old Apr 28, 2013 | 11:11 AM
greggbruce's Avatar
Car: 84 454 monte, 89 formula, 86 camaro
Engine: the bigger the better
Transmission: 700/4L60 in everything
Axle/Gears: wish they were all 4.10's or better
Re: TunerPro Newbie need some help
you have to open the bin file as well as set the $6e xdf as well to see the info
Old Apr 28, 2013 | 11:12 AM
Car: 1987 Trans Am
Is there a quick explanation as to how I would go about that?
Old Apr 28, 2013 | 11:22 AM
J_D_'s Avatar
Download the ARAP bin for a start. Save it in Tunerpro and you can open it there.
Old Apr 28, 2013 | 11:24 AM
greggbruce's Avatar
the mask (xdf) tells the program how to decipher the actual information (.bin file) because they are different for different years...
you have to find a .bin file to download first, save it to the tunerpro folder
here: http://www.gearhead-efi.com/Fuel-Inj...ams-Tuner-Info
but I would read this first:
http://www.gearhead-efi.com/Fuel-Inj...-a-must-read!-)
Old Apr 28, 2013 | 11:31 AM
Car: 1987 Trans Am
Okay thanks guys I figured it out and I read the short tutorial link, it had about the same information from what I found on this forum. Do you guys know where would be a good place to look to start researching how the 2D tables work so I can start reading up on that for when I get to that point?
Old Apr 28, 2013 | 11:33 AM
Car: 1987 Trans Am
Also I have 3 bin files to choose from ARAP, ANZA, and APYP which one would be the best to look at to start "tinkering" with to learn how the software works?
BTW I have a 87 Trans am 305 tpi
Old May 2, 2013 | 12:45 PM
greggbruce's Avatar
I would think you would want to start with the factory file -- but I don't know very much about this stuff either....
I found a list of 1987 files, so you can have your pick...
http://www.gearhead-efi.com/Fuel-Inj...nformation-32B
junkcltr
26
Jan 22, 2022 10:53 AM
Mark_ZZ3
May 24, 2018 01:02 PM
rubblerubble
Mar 13, 2016 06:57 PM
ULTM8Z
Oct 2, 2015 01:25 PM
tmellott89
Aug 16, 2015 02:58 PM
