TunerProRT (old Version) question
Old Jun 20, 2013 | 11:56 AM
jackballs529's Avatar
Car: 1987 Iroc-z
Engine: 355/Edelbrkhds/lpe219cam/MiniRam/
Transmission: 700R4/3.27 9bolt
Guys, I'm trying to take a "Session" recording and make a readable excel file. I hit the "export Selected Session To CSV" button and then I name the file and put it into the "DataStreams" folder. The problem is: how do I pull that file out of the "DataStreams" folder to read in excell and also be able to email it. If I open the DataStreams folder and click on the file, it says "the file name already exists. Do you want to replace it? What am I doing wrong?
Old Jun 20, 2013 | 12:22 PM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
Re: TunerProRT (old Version) question
I believe when you export it to a CSV (comma separated value file) you can then go to windows explorer and open it as an excel file.
What version are you using?
Old Jun 20, 2013 | 02:36 PM
Car: 1987 Iroc-z
How do I find and bring up the file through Explorer? I need to be able to save it so I can email it.
Old Jun 20, 2013 | 03:13 PM
Car: 89 Formula
Engine: 383 SBC/HSR
Once you convert it to a csv file, it is saved....just in a different format.
Try This: Open Excel and go to the folder where you exported the file. Excel’s default option is to only look for “Excel Files”. Change that setting to “All Files”. You should now be able to see the file, double click on it, and then save it as an Excel file.
That works on my version....not sure how old your is. You might want to update.....it's free.
Old Jun 20, 2013 | 03:33 PM
Car: 1987 Iroc-z
It Says "path does not exist" or "file not found".
Old Jun 20, 2013 | 03:40 PM
Car: 1987 Iroc-z
Just tried it in Version 5, same deal. Can someone walk me through the procedure i am obviously doing something wrong.
evilstuie
Feb 28, 2016 03:33 PM
87iroctheo
Wheels and Tires
Sep 2, 2015 03:29 AM
dm3k
Brakes
Aug 29, 2015 01:53 PM
EFR2000
Aug 18, 2015 08:54 PM
redmaroz
Aug 16, 2015 11:40 PM
