doing something wrong with writing chips
Old Apr 11, 2014 | 12:45 PM
  #51
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
Re: doing something wrong with writing chips
Originally Posted by Fast355
High vacuum would be the 20-30KPA side of the table, not the 80-100KPA side. 80-100 KPA is were you are under heavy load and wide open throttle.
The backfire while decelerating maybe the fact the ecm is no longer entering deceleration fuel cutoff correctly due to the reduced vacuum of the longer duration camshaft.
now this part is REALLY good to know.
so basicly under high vacuum, you want more timing due to less load on the engine...
and with the 2d VE table you probably want to mess wih the 2d table if your fuel is hgih or low all over that RPM range.
and mess with the 3d tables to finetune when on a specific load/rpm you need more or less fuel.
Old Apr 16, 2014 | 07:15 PM
  #52
doctorbigblock's Avatar
Are you putting chips into programmer with chip inserted all the way down leaving open pins at the top?
Fanatic1074
Oct 3, 2022 05:57 AM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Gunner242
Dec 25, 2015 04:49 PM
meeklay812
Oct 1, 2015 03:46 PM
