$0D - CTS Spark Advance Compensation vs. Vacuum vs. Temperature
Old 08-08-2014, 03:08 AM
code-'s Avatar
I'm getting some knock only above 90 Celsius and was hoping to use this table to correct it. I need some clarity regarding this table, what are the units for the columns? 80-0 what exactly? The spark retards the further right you get I'm sure its not kPa? It seems strange that kPa is used everywhere but here.
Attached Thumbnails alt=
Old 08-08-2014, 07:11 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: $0D - CTS Spark Advance Compensation vs. Vacuum vs. Temperature
It is KPa, in vacuum from barometric. So 0 KPa is WOT. 80 KPA being off the throttle decel.
The ECM calculates vacuum by subtracting the current MAP reading (in KPA) from the current barometric value.
Example: with barometric at 101 KPa (slightly above sea level) and the current MAP is 60 KPa (light cruise), the vacuum is 41 KPa.
RBob.
Old 08-08-2014, 07:53 AM
code-'s Avatar
Perfect, thanks!
GTAman
09-21-2015 09:57 AM
Todd84Z
09-04-2015 08:02 AM
db057
09-04-2015 07:57 AM
htrdbmr
08-31-2015 07:28 PM
Armored91Camaro
08-12-2015 09:41 AM
Quick Reply: $0D - CTS Spark Advance Compensation vs. Vacuum vs. Temperature
