$8D Open loop cold start problems
Old Aug 11, 2014 | 10:38 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
7730 $8D. 350 TPI, 5spd, Edelbrock Vortec lower, Vortec heads, SLP siamesed runners, comp cam xe274 (.490/.490 230/236) 24lbs injectors. No smog or AIR, but I have the charcoal canister still.
On a 100% cold start I have really bad stuttering/chugging when I try and drive. The idle seems about as smooth as the car gets. Once it goes into closed loop everything is fine.
Not sure if it is a rich or lean condition.
I pretty much zeroed out the Loop Open Param, AFR % Change Vs. Coolant and the Startup Enrichment Vs. Temp tables. It seemed worse on startup. I put the startup enrichment vs. temp table back to stock and it seems to no stutter as much.
What should I be looking at to make a cold startup run smooth?
Old Aug 12, 2014 | 11:52 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: $8D Open loop cold start problems
Have the VE tables been tuned in yet?
RBob.
Old Aug 12, 2014 | 12:57 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
RBob.
I was working with Tuned Performance on the VE tables. He said he got them pretty close. I haven't been in contact with Brian for over a month though.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
