Cold start for $32B
Old Aug 22, 2014 | 02:50 PM
Mapleleafs98's Avatar
Cold start for $32B
Hi there, I have an 86 Camaro with a ZZ4 350, TPIS mini ram, 24lb Bosch injectors and a tremic TKO 5speed. I got a tune built off an ACXZ bin file which is a $32B. I just want to know how I can richen up my cold starts as the 9th injector is deleted and I need to crank a few times when the engine is cold but fires up perfect when it warm. $32B doesn't have as many tables as $6E so I was wondering how I can get a better cold start?
Old Aug 22, 2014 | 03:16 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Cold start for $32B
Increasing this value will increase cranking fuel:
LC36C: FDB 6554 ; Scale Factor for Max Crk P.W.
May need to reduce the fuel at warmer engine temperatures via this table:
LC36E: ; CRANK FUEL vs COOLANT Temp.
There is also after start enrich tables that will help on a cold engine.
Have you considered going to $6E? Seems that those who did were happy with the results.
RBob.
Old Aug 22, 2014 | 03:24 PM
For some reason every time I tried a $6E the cold running of the car was horrible until it warmed up for about 10-15mins so I decided to stay with a $32B because the car ran really good with the stock prom from an 87 5speed. That's why I decided to go with that as a starting bin.
I am not to familiar with what you mean by: LC36C, FDB 6554; and LC36E?
Could I not just adjust the crank fuel vs coolant temp and that's it?
Old Aug 22, 2014 | 05:40 PM
here is my bin file with no adjustments for cold start
won`t let me post it? :-(
Old Aug 23, 2014 | 09:39 PM
Hi there, I actually just tried to increase the cold values in the crank pulse width vs coolant temp by about 15% and the thing starts up perfect now when it's cold. Thanks.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
