Is Hypertech memcal causing my problems?
Old Dec 20, 2015 | 05:17 PM
Johnny Gun's Avatar
Car: '88 GTA
Engine: 355 SBC, AFR 195 heads, Stealth Ram
After I got my burning hardware, I found that I have a Hypertech memcal in the ECM. The car runs fine on the Hypertech, just takes forever to start up (no cold start valve).
I have it plugged into the Moates adapter correctly.
No matter what bin/mask combination I run through the Ostrich, it just won't run. Sometimes I get limp home mode. Sometimes it cranks immediately dies. Sometimes it runs if I hold the gas and the exhaust fumes are thick and smell like eggs.
From what I've read, inserting the memcal unit into the Moates adapter bypasses the chip on it and only allows access to the limp home circuit. If that's the case, I can't figure out why the Hypertech chip would be causing problems.
Should I track down an actual stock memcal and start over? I'm at a loss.
Old Dec 21, 2015 | 10:11 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Is Hypertech memcal causing my problems?
Are you getting the CEL/SES blink at key-on, engine-off? That verifies that the ECM is running from the Ostrich.
RBob.
CapsFan
Aug 12, 2016 10:30 AM
blue86iroc
Dec 7, 2015 07:30 AM
Dr.E
Nov 23, 2015 11:39 AM
reborn92rs
Brakes
Nov 23, 2015 01:02 AM
