Looking for EBL experiance
Re: Looking for EBL experiance
My last tuner would agree with you- but it is what I have. When it runs good- it's great, no issues other than self inflicted for several years of running it. Anyway you comment is not constructive.
Car: check
Engine: check
Transmission: check
RBob.
I did change out that ignition switch from the original because of the irratic ign voltage on key off- what else would affect this?
Dave
Car: check
Engine: check
Transmission: check
I have trouble with being charged a good $$ for that garbage. I decided to start with your regular vortec tune----> just with a good account for injector and cid it's running far better than when it was given to me, not even a VE learn yet. The talent pool here for this is non existent, it would be nice to have some knowledgeable guy (or gal) in the pass seat- so to speak. Saying that, I've had the EBL for many years and want to thank you for all the help you've given.
I did change out that ignition switch from the original because of the erratic ign voltage on key off- what else would affect this?
Dave
Dave
That same fuse also powers 2 solenoids (EGR & EAC) and the ESC Module.
RBob.
I found a fellow who is willing to work with me online- he probably contacted you about using .adx with TunerProRT/wud, is there any articles about this or step by step on what's involved...kind of lost on this one.
Car: check
Engine: check
Transmission: check
No sense monitoring the ALDL stream, the EBL data stream provides much more information and at a higher data rate.
Just use the WUD to data log and analyze the data.
RBob.
RBob.
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
