730 'puter VE Table Adjustment
1 Post
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
OK, it seems I got conflicting instructions to tweak the VE tables.
Trax says to set the injector constant once and leave it alone, now tune the VE tables.
Glenn says use the injector constant as a course adjuctment and tweak the VE tables for fine adjustments.
Thing is I have 24# injectors and my constant is up to 27# to get good BLM's. Should I change the constant to match the injectors or what?
If I mis-understood Trax or Glenn I am sorry, just learning some more.
Car: Death Mobile
Engine: 666 c.i.
Actually, once you find an Injector Constant that get's you close to 128/128 for most of the VE table, you should never have to go back to the Injector Constant and only have to work on the VE Tables for "fine tuning".
What I don't advocate is using the Injector's "rated flow" as the Injector Constant and just tuning the VE Table (except if it happens to be fairly close to 128/128). The reason is because once you have set your fuel pressure to what you want to run (and most of us increase to fuel pressure to the 46-48 psi range to get the better atomization), I seldom find the "rated flow" is correct.
FYI, SVO 24# injectors are rated at 38 psi. If you increase the fuel pressure to 48 psi, it now has the equivalent flow of 27# injectors.
1 Post
Engine: 4.0L
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
If I calculate my BPW constant, by the books it should be 135. I was rich all over so I set it to 133. Now I'm tuning the VE tables using 133 as my BPW.
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Basically, when you are focusing on the VE tables and tweaking the VE tables you want to leave the Injector constant alone. I am not saying that you should not make some coarse adjustments using the injector constant BEFORE you tweak the VE tables .... I am just saying that once you start tweaking the VE tables that you want to leave all other variables in the fuel system alone (i.e. don't change the fuel pressure, don't swap injectors, don't change the injector constant, etc).
Tim
Tim
LT1Formula
10-08-2015 08:34 PM
