EBL Flash voltage compensations
Car: 1990 Camaro IROCZ
Axle/Gears: 3.45
So i'm looking to run a Bosch 0-280-155-700, I would like to input some voltage offset data. But the only table i'm finding is INJ - injector correction offset, it is volt vs usec. Is there another table?
Axle/Gears: 3.45
Re: EBL Flash voltage compensations
The offset table that i see for injectors are in volts vs mSec, these tables are in usec . Can you convert usec to msec? or am i missing something?
thanks
Steve
thanks
Steve
Axle/Gears: 3.45
So my plan is to use the offset tables you post here:
https://www.thirdgen.org/forums/diy-...gn-iii-pw.html
How spot on does the tables need to be? My other option would be to send and injector out and have it tested.
Thanks RBob
Thanks RBob
Car: check
Engine: check
Transmission: check
Your question & comment doesn't make sense. If you have those injectors and the data for them...
RBob.
RBob.
Axle/Gears: 3.45
Ok so there is he story, these injectors came in my car when I bought it, someone had a chip burned at some point in time. Just trying to input the correct data to the EBL flash. The only voltage offset numbers I could find is from and old post you respond to. What I'm trying to ask should I send out an injector and get actual voltage offset data from the injector, or use the data found on the internet? Also so is there anything thing else I would need to change to make these injectors work correctly?
Car: check
Engine: check
Transmission: check
I did a better job reading the other thread. Upon checking my notes they are not the correct offset values. Since that time, as mentioned as a possibility, it is for the older fat yellow tops (not skinny yellows).
I don't have the data for the 280-155-700 injectors.
It is best to get the correct values. Just not sure from where.
RBob.
RBob.
Axle/Gears: 3.45
These are the guys I'm looking at using, http://www.deatschwerks.com/support/...ector-services
