1987 Iroc Camaro Idling Issues
Old Mar 24, 2018 | 06:26 PM
camaroyoungster's Avatar
Car: 1985 Camaro Sport Coupe
Engine: Chevy 3.1
Everyone, I am trying to diagnose an idling issue on a camaro with a 350 has a slightly hotter cam that I don't the specs of but we are having issues with it being very rich. We can tell because it smells like fuel pretty bad and when you step on it you can see black smoke. I attached a log file if you guys could give a look at it. Fuel pressure looks good for the most part.
Drew
File Type: txt
Old Mar 25, 2018 | 11:45 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 1987 Iroc Camaro Idling Issues
There is an O2 sensor rich code set (45). It looks like the BLM is at 118, which is pulling a lot of fuel. A lot of the log file is difficult to understand.
None of the log is at idle.
Tap on the MAF sensor and see if that makes the engine stumble. Other possibilities are leaky injectors or the base timing is not set properly.
RBob.
Old Apr 2, 2019 | 07:55 AM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
but unless you're having a high idle, i wouldn't think it was a vacuum leak. What does your car idle at? It sounds more like fueling to me.
Old Apr 5, 2019 | 10:22 PM
bowtieboy1987's Avatar
Car: 87 iroc z28 camaro
Engine: 350ci
Transmission: thm 700r4 auto4speed
Axle/Gears: 3.23 rear ratio preformance rear ax
i have a 87 iroc z Camaro 350 it keeps telling me that mass air flow sensor is bad .replaced maf sensor, an relay and still tells me I have a 36 code
Old Apr 6, 2019 | 10:56 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Does you maf have a burn off wire ?
Kitten Tooth
Dec 31, 2016 04:27 PM
jjg
May 30, 2006 02:34 AM
85f-bird
Jan 28, 2006 12:31 PM
trueburton
Mar 28, 2005 04:01 PM
91RSHawaii
Nov 3, 2004 10:03 PM
