How to get the adx file from tuner pro
Old Jun 4, 2018 | 05:22 PM
T-Smith's Avatar
It won’t let me download it it just tells me to save target as
Old Jun 4, 2018 | 08:09 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: How to get the adx file from tuner pro
At that dialog do a save file. Navigate to the folder to place it and then select the save button. I can't explain exactly what steps to take as it varies among the different browsers.
RBob.
Old Jun 4, 2018 | 10:47 PM
T-Smith's Avatar
What windows are you running and how do I save it as a adx
Old Jun 4, 2018 | 10:49 PM
T-Smith's Avatar
When I save it and go to run it through Tunerpro it Just Saves the link and not the file it’s saves it as html
Old Jun 5, 2018 | 09:37 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Do a right click on the file to download, and select the Save Link As... Should then be able to save it as the proper file.
RBob.
Old Jun 5, 2018 | 09:40 AM
T-Smith's Avatar
Every time I right click to do that it just says save target
Old Jun 5, 2018 | 10:03 AM
ULTM8Z's Avatar
which adx file are you trying to download?
Old Jun 5, 2018 | 10:05 AM
T-Smith's Avatar
90-91 L98 one $8D
Old Jun 5, 2018 | 11:00 AM
ULTM8Z's Avatar
See if this works. Download this and change the .zip extension to .adx.
It wouldn't let me post an adx file directly so I renamed it to zip.
File Type: zip
Old Jun 5, 2018 | 11:12 AM
T-Smith's Avatar
can you give me the xdf on too
Old Jun 5, 2018 | 11:19 AM
T-Smith's Avatar
it wont let me unzip it. It says before you extract files you must copy files to this computer
Old Jun 5, 2018 | 11:53 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Turn off all of the anti-virus stuff on the laptop/PC you are downloading too.
RBob.
Old Jun 5, 2018 | 12:54 PM
ULTM8Z's Avatar
Either that or PM me your email and I'll send you the files
Old Jun 5, 2018 | 12:57 PM
T-Smith's Avatar
i turned everything off and it didn't work
Old Jun 5, 2018 | 06:04 PM
ULTM8Z's Avatar
I sent the files. But I also sent the suite of S_AUJP files (bin, ECU, adx, and xdf). I'd highly recommend starting with S_AUJP. It has a lot of nice added features and capabilities.
Old Jun 5, 2018 | 08:22 PM
T-Smith's Avatar
Thanks I can’t go to go to town on this
Old Jun 6, 2018 | 10:23 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
You have some sort of laptop/PC problem. Either the anti-virus is still running in the background, security level on the folder/system is too high, firewall is running interference, and so on.
As an example I used to run the ZoneAlarm firewall. But they kept adding stuff to it that made it more then just a firewall. It prevented me from decompressing zipped files that I down loaded from the 'net.
Needless to say that ZoneAlarm is now gone.
RBob.
Old Jun 6, 2018 | 10:27 AM
T-Smith's Avatar
How do I get rid of my firewall
Old Jun 6, 2018 | 10:35 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I don't know.
RBob.
brando278705
Aug 13, 2018 10:13 AM
zapc
Dec 10, 2016 10:58 PM
DemonYusuke
Mar 13, 2016 02:02 PM
I_R_O_C_Z_2_8
Feb 28, 2016 07:45 PM
dave w
May 13, 2011 05:26 PM
