i just purchased my autoprom and gp1 package from moates and i need help finding the correct xdf and bin files the car is a 87 irocz originally had the ho 305 700r4 with 2.73 gears now i have a 350 world class t5 and same 2.73s previous owner put in the correct 350 memcal ABYA idk were to start nothing really shows me what to do and to clarify im using tunerproRT and i also dont even know why i need the bin or xdf file cand someone bless me with their knowledge and lay it all out for me
You need the XDF to tell tunerpro where the tables are for your bin.
You need the bin because without it you don’t have a file to alter or upload to the ECU. There is a way around that and that’s to pull your bin file off the ECU.
As far as the where and how I think the stickies go over the whole thing pretty well. Start there.
ok thank you were are the stickies?
You should start with apyp and recurve the timing try aujm timing tables or your current Abya.
the advanced timing of a automatic will help with acceleration.
Here are some bins if you want to go with $6e
http://www.gearhead-efi.com/Fuel-Inj...Information-6E
alright thanks guys i appreciate you guys didnt start flaming me i started to tear my car apart for por15 and subframe connectors so i wont be tuning it untill i finish with that
hey isnt the apyp from the vettes will this work?
