EBL WBO2 Tuning Spreadsheet
Old Nov 29, 2018 | 09:33 AM
dave w's Avatar
Sample screen shots of an EBL WBO2 tuning spreadsheet I've been working on. Copy paste the exported EBL .csv into a spreadsheet for "Closed Loop" tuning data. I'm trying to figure out the Knock Retard worksheet.
Thoughts / Suggestions are welcomed.
dave w
Old Nov 29, 2018 | 11:51 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: EBL WBO2 Tuning Spreadsheet
Very cool
Old Dec 4, 2018 | 09:32 AM
RJ IROC's Avatar
Car: 1985 Camaro IROC-Z
Engine: 383 HSR Comp XFI280HR Profiler 195s
Axle/Gears: 3.73 Posi
This is super cool. Any interest in sharing? I'm good with excel, just haven't tried anything like this before.
I think it would be worthwhile to create a sheet that can give you the average difference in observed AFR, or even a difference in BLMs, versus airflow over the course of a log. That has the potential to make tuning IAT values incredibly straightforward.
I'd also be interested in a sheet that could analyze acceleration enrichment, or at least compare average differences of delta TPS AE effects on the AFR.
I'm sure I could come up with more over time. Really digging your spreadsheet though! Let me know if you mind sharing!
Old Dec 4, 2018 | 11:17 AM
ULTM8Z's Avatar
i did something with a IAT tuning tool a while ago...
https://www.thirdgen.org/forums/diy-prom/747591-mat-analysis-tool.html
it basically eliminates all other variables and reduces the data down to just AFR vs IAT.
Old Dec 4, 2018 | 01:56 PM
dave w's Avatar
The spreadsheet is for the Dynamic EFI - EBL System, still interested?
I was commissioned to author the Spreadsheet, so I'm only comfortable sharing the "Base Formulas" to build / create / author a spreadsheet.
Hint:
Average If ... https://support.office.com/en-us/art...9-f5576d8ac642
Count If ... https://support.office.com/en-us/art...4-1f464816df34
dave w
Old Dec 4, 2018 | 02:09 PM
RJ IROC's Avatar
Still interested Dave. I've been tuning with the EBL for a few years now, and this would be a great tool to work with. I checked out the the tool that ULTM8Z talked about, and I'm interested in that as well. The link for the ULTM8Z MAT tool wasn't working, so I haven't been able to download it yet. I would imagine the MCC works similar to the IAT calculations of the EBL. Not sure exactly how the bias term of EBL works with an inverse MAT/MCC; it couldn't be as easy as inverting it could it? I'm lacking in knowledge of that part of the fueling calc.
Old Dec 4, 2018 | 04:30 PM
dave w's Avatar
The formula for WBO2 averaging "lower RPM cell 1200 RPM @ 50 Kpa" is: =AVERAGEIFS('Pasted CSV'!AW:AW,'Pasted CSV'!D: D,">=47.5",'Pasted CSV'!D: D,"<=52.49",'Pasted CSV'!B:B,">=1150",'Pasted CSV'!B:B,"<=1249",'Pasted CSV'!AC:AC,"=Y")
The formula for WBO2 averaging "upper RPM cell 3600 RPM @ 70 Kpa" is: =AVERAGEIFS('Pasted CSV'!AW:AW,'Pasted CSV'!D: D,">=67.5",'Pasted CSV'!D: D,"<=74.99",'Pasted CSV'!B:B,">=3500",'Pasted CSV'!B:B,"<=3799",'Pasted CSV'!AC:AC,"=Y")
The formula filters for closed loop WBO2 data which is column AW "IF" column AC = Y
The formula is specific to the VE table, meaning every cell in the VE table has it's own formula.
dave w
Old Dec 4, 2018 | 10:57 PM
RJ IROC's Avatar
Thanks for that Dave!. I can see how the functions work, only averaging the values in between the RPM and KPA thresholds for each cell. The tedious part appears to be having to change the four thresholds in the formula of each cell. I might play with this a little, and try to come up with something useful. I'll post back here with any updates. Thanks again!
Old Dec 5, 2018 | 09:19 AM
dave w's Avatar
Interesting thought: Actual Spark Advance vs. Spark Table / Actual AFR vs. VE Learns .... something useful not provided by the WUD? Useful data that might or might not leave the competition looking at tail lights vs chasing tail lights.
Agreed, staying ahead of the competition is TEDIOUS!
dave w
Old Dec 5, 2018 | 09:38 AM
RJ IROC's Avatar
Dave, that's a great idea. Leaving fueling constant, you could analyze how WOT AFR is affected by a change in timing. Visual display of a delta AFR for each of the RPM points among multiple advance curves would be interesting to see. Procedure would be pretty simple; make a few .bins with the only change being the advance at WOT, flash them, do a WOT pull, change to other bin, another pull, another WOT pull, another change...etc. Once done, chuck the three logs into a spreadsheet, Use fancy excel functions to grab relevant data from each log, and display the differences. Neat stuff!
Old Dec 5, 2018 | 12:48 PM
dave w's Avatar
Some call that "Tuning"
dave w
Old Dec 5, 2018 | 01:09 PM
ULTM8Z's Avatar
Still interested Dave. I've been tuning with the EBL for a few years now, and this would be a great tool to work with. I checked out the the tool that ULTM8Z talked about, and I'm interested in that as well. The link for the ULTM8Z MAT tool wasn't working, so I haven't been able to download it yet. I would imagine the MCC works similar to the IAT calculations of the EBL. Not sure exacetly how the bias term of EBL works with an inverse MAT/MCC; it couldn't be as easy as inverting it could it? I'm lacking in knowledge of that part of the fueling calc.
Send me an e-mail... I'll e-mail you the file. Though, mine only works when using the S_AUJP suite of files... .bin, .adx, and .xdf
ultm8z@yahoo.com
Old Feb 3, 2019 | 01:58 PM
dfarr67's Avatar
Any updates?
69sixpackbee
Jul 1, 2011 09:38 PM
BronYrAur
Nov 12, 2007 06:45 PM
Scott T
Aug 14, 2003 07:42 PM
87_TA
Jan 18, 2003 11:15 PM
Damon
Carburetors
Nov 13, 2000 10:32 AM
