Can no longer connect to '165 ECU $6e adx
Old Jun 22, 2019 | 11:24 AM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
Hey all,
Hoping for an assist here. The other day I removed my dash to fix my blend doors. Got it all back together and now I can no longer connect to my ECU via Tuner Pro RT w/Moates ALDL 1 cable.
I have confirmed continuity from ECU pin A8(orange) to ALDL Pin E, and from ECU Pin A9(wht/blk) to ALDL Pin A.
I have also tested 2 different ECUs and 2 different Memcals, I reburned one of them as well.
Suggestions on what might have gone wrong?
Old Jun 22, 2019 | 12:20 PM
Engine: 383 HSR EBL
Re: Can no longer connect to '165 ECU $6e adx
Never mind. It is now connecting again. So weird...
Old Jun 23, 2019 | 02:29 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
They are picky sometimes. I for many years (15+) have never had big issues connecting. It might take a few tries here and there. But last year the car gave me some issues. And it was a complete pain to get my ecm to connect. I'm talking 10-15 tries. And nothing changed in the vehicle.
Old Jul 3, 2019 | 07:11 PM
Engine: 383 HSR EBL
Well I am back to having major connection issues.
If anyone could help me start at the basics I'd appreciate it as I am stuck mid tune for my new engine.
What is required for a successful connection? Particular pins on the ecm and aldl?
How do I enter TunerPro Rt's connection debug data stream window?
Things I have tried:
Verified grounds on all ECM grounds are under 10 ohms.
Verified ALDL ground is under 10 ohms
Verified continuity between A8 and ALDL B
Verified continuity between A9 and ALDL E
I just get mostly no connection, but at times it snaps right in and connects. Mostly does not though.
I cannot for the life of me find Tuner Pros debug logs, but I was able to with ALDLDroid, and it seems both my ECMs are responding with 0 bytes of data for some reason.
Old Jul 11, 2019 | 05:29 PM
Engine: 383 HSR EBL
Turns out it was the USB portion of the ALDL Xtreme that was the problem. Replaced that and gtg again.
oddscrounger
Jul 11, 2017 04:26 PM
GreekItalianMan
Sep 24, 2013 01:13 PM
Project 3.4 Camaro
Jan 1, 2012 09:17 PM
Project 3.4 Camaro
Sep 12, 2011 06:39 PM
chooch-88formula
Jun 29, 2001 02:12 PM
