Vats Trouble Code 46
Old Aug 15, 2021 | 04:59 PM
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
Transmission: 5 Speed
I was literally putting the final chip in the ecm and now I'm getting a "no start". I'm getting a code 46 and mark where Vats OK is listed. So it's the vats, fine. I deselected enable vats, burned a new chip and it still won't crank. And it pulls the same codes. I did wait 10 minutes between tries. I have a 92 tpi using 7730 ecm. According to what I read, I should be able to just to uncheck the vats enable/disable and it should start. I shouldn't have to bother with the fuel relay, right?. I do hear the fuel pump engage. What are my choices? Bypass module? Or could the EBL solve the problem?
Old Aug 15, 2021 | 05:02 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Vats Trouble Code 46
Will it crank ? Starter enable relay bypassed?
Old Aug 15, 2021 | 05:19 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
I could be wrong, but I believe your VATS module does 2 things (when it's working):
1. Grounds the starter bypass relay when IGN is in Start.
2. Sends a square wave to the ECM that enables injector pulse.
So, tuning it out of your chip will let the injectors pulse, but you still need to bypass the starter relay to send juice to the solenoid.
Old Aug 15, 2021 | 05:39 PM
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
It doesn't crank at all. I thought I wouldn't have bother with the relay due to the tpi.
Old Aug 15, 2021 | 05:46 PM
Engine: Lb9
Transmission: M20
There’s you problem
Old Aug 15, 2021 | 06:47 PM
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
Nuts, nothing is ever simple.
Rick Nielsen
Oct 14, 2020 07:47 PM
TheSumOfOne
Feb 21, 2013 11:31 AM
robscamaro91
Apr 7, 2011 02:35 PM
HillbillyJeeper
Aug 6, 2005 09:00 AM
87transam5.7tpi
Jun 1, 2003 04:57 PM
