Routing Wideband Data Cable Through Firewall
Old Apr 3, 2022 | 05:05 PM
thainglo's Avatar
Engine is out and I'm knee-deep into converting from carb to TPI. Using an Innovate LM-1 kit and planning to mount the sensor in the tube that PO replaced the catalytic converter with. I was going to drill a hole sized to the cable and run a pass-thru near where the ECM wiring goes, but now see that the plug on the end of the cable won't allow a tight fit through a grommet.
How have others gone into the cabin?
Here are pics for a bit better description...
Plug that connects to the command module inside the cabin. Larger than the cable diameter.
Had planned to go through this area with a hole and grommet, similar to the amplifier power wire that is above the ECU plug.
Old Apr 5, 2022 | 06:39 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
Re: Routing Wideband Data Cable Through Firewall
How long is your cable? I think, I routed mine along back of firewall, (top of it), to passenger door, and maybe under the seal, and then down under the dash. I have a very old LM1, large box, and I have it mounted to the right of the steering wheel, on dash.
Old Apr 5, 2022 | 08:31 PM
thainglo's Avatar
I think I have an 8' cable. Spent this morning working on the wideband solution. I decided to go in through the HVAC grommet, had to slice it and remove a small chunk for the cable to go through and still allow the grommet to seat fully. Used a bit of spare silicone caulk to seal it back up.
Not sure if this route would be accessible with the engine in place, as it is pretty far down in there!
Old Apr 11, 2022 | 10:51 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
You can get large OD with small ID grommets for just such an occurrence, or hole plugs where you can cut your own hole into, for future reference
Old Apr 11, 2022 | 11:42 AM
skinny z's Avatar
I followed the factory routing for the ECM wiring (ECM is long gone).
From the engine bay, over the passenger side inner fender, behind the fender itself and into the cabin through the large grommeted opening in the door jamb. You end up behind the kick panel.
Marc Maro
Sep 6, 2011 09:20 AM
GTA Sammy
Mar 19, 2010 12:13 PM
Mike89GTA
Mar 11, 2004 09:17 AM
Electromaro
Feb 28, 2004 07:20 PM
