EBL troubleshooting
Old Apr 27, 2022 | 08:18 PM
edixon24's Avatar
Car: 1990 IROC
Engine: 383 Trickflow HSR
Transmission: auto
EBL troubleshooting
Car left me stranded. Towed it home and changed the ignition control module. starts right up but now has an SES light. I took a data log to try and get an idea (attached) I'm scratching my head. my O2 sensor starts going crazy at about 40 seconds in. I cant confirm it wasn't doing that before as its been a long time since I hooked up to the EBL and checked things out but why the SES light all of the sudden? I changed a Map sensor a couple weeks ago and the car ran fine. then I changed the map sensor connector in the process of pulling the distributor to change the ignition control module.
File Type: zip
Old Apr 28, 2022 | 05:12 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: EBL troubleshooting
IAT/MAT low, did you unplug the sensor and not plug it back in? A low error on IAT/MAT is basically an open circuit. Can see in the WUD Diagnostic display that it is an open circuit. Reporting -40°F/°C to the ECM.
RBob.
Old Apr 28, 2022 | 07:22 PM
edixon24's Avatar
Car: 1990 IROC
Transmission: auto
I'm seeing something different than you are Rbob. Maybe i have an outdated version of the WUD? Im showing oil temp at -40 but CTS and IAT at 59/63 degrees.
Old Apr 29, 2022 | 04:45 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
To see the raw, real, actual sensor values use the WUD Diagnostic display. Otherwise you are looking at default values that the ECM creates and uses when there is a bad sensor.
RBob.
Old Apr 29, 2022 | 04:49 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
RBob.
Old May 2, 2022 | 08:15 AM
edixon24's Avatar
Car: 1990 IROC
Transmission: auto
Thanks Rbob. Cleaned connector. Problem solved.
James Sutton
Jun 29, 2018 09:11 AM
BthomasM
Jan 5, 2009 10:25 PM
five7kid
Mar 14, 2002 10:42 AM
BuddyLeeX
Jan 15, 2002 08:41 PM
HrdRockA4305
Apr 17, 2001 07:34 PM
