Symptoms of oxygen sensor failure.
Old Jun 21, 2018 | 08:23 PM
James Sutton's Avatar
Car: 1991 Camaro RS yellow
Engine: was '91 V6, now '89 5.7/355 TPI
Transmission: 4 speed automatic
Axle/Gears: Moser 3.73 with zexel posi
What are symptoms of oxygen sensor failure? My trouble light comes on intermittently on the road, and engine then runs rich with a power loss & no acceleration. Goes away on restart.
Also weird: Trouble light comes on intermittently at startup, but if I turn off the ignition and wait 20 seconds to restart, trouble light goes off & all is okay. VATS?
Haven't checked codes, yet.
Old Jun 21, 2018 | 10:42 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Re: Symptoms of oxygen sensor failure.
O2 sensor is the only sensor on the car that actually generates voltage.
Connect a voltmeter to the sensor, and observe voltage delivery once the sensor is at operating temperature.
http://www.autotap.com/techlibrary/u...en_sensors.asp
Old Jun 22, 2018 | 07:53 AM
Thank you. Very helpful explanation on this site.
Old Jun 22, 2018 | 01:59 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I would try to pull the codes. The reset of the ecm and all is well sounds like it could be a faulty ecm. But start with the stored codes first then trouble shoot from there.
The o2 swings from .450mv up and down. Stuck at .450 it’s inactive due to being bad or not upto 5-600f to become active.
Old Jun 23, 2018 | 09:39 AM
No codes. ECM replaced recently, no change in bad behavior.
Old Jun 23, 2018 | 04:11 PM
W.E.G.'s Avatar
Engine: V6 2.8
What modifications are present on this vehicle?
Old Jun 24, 2018 | 12:47 AM
No Cat, so no after O2 sensor; replacement engine bored out to 354 cubes, TPI, with rollers & performance harness; Flowmaster muffler; 3-core radiator & elec. fans; MAF is from a Corvette. Cluster replaced & board added for tach accuracy. The engine is "Wonder" brand & has bore holes through the water jacket, so there could be a leak, though I plugged one (of two) with a stud. Sometimes, dipstick pops up. (blow through?) Cruise control works, but won't hold constant speed & causes car to throb. (ECM getting bad 02 sensor data or vacuum leak under the dash?) Whew!
Old Jun 24, 2018 | 01:24 PM
Engine: Lb9
Transmission: M20
Have you got around to pulling the trouble codes ?
Old Jun 24, 2018 | 02:05 PM
W.E.G.'s Avatar
Engine: V6 2.8
Running a MAF that isn’t matched to the ECU could cause interesting issues.
I suppose once you know your O2 sensor is feeding dynamic data to your ECU, you could start to tailor your fuel map to achieve a stochiometric condition across the fuel-map.
Curious why not using original-spec MAF sensor?
If you suspect vacuum leaks, get a decent smoker, turn out the lights, and break out the penlight.
Old Jun 24, 2018 | 02:07 PM
Engine: Lb9
Transmission: M20
Although the maf came from a corvette it’s the same part number as a f body.
MAF units from 86-89 models output a simple analog signal instead of using frequency modulation like the 1985 units. So as long as your not running one from a 85 it should be fine.
YEAR ENGINE OE #
Camaro Z28
1989-1988 5.0L (F) 305" 10055877
1987-1986 5.0L (F) 305" 14094712
1985 5.0L (F) 305" 14081243
1989-1988 5.7L (8) 350" 10055877
1987-1986 5.7L (8) 350" 14094712
Corvette
1985 5.7L (8) 350" 14081243
Old Jun 24, 2018 | 03:18 PM
Car was a restoration; the MAF was already in it & worked, so I didn't change it.
Old Jun 28, 2018 | 12:34 PM
Replaced Oxygen sensor; all symptoms disappeared. Learned that shank on sensor with Flowmaster muffler is longer than shank on stock 02 sensor for this vehicle. Thank you for your help.
Old Jun 28, 2018 | 07:49 PM
W.E.G.'s Avatar
Engine: V6 2.8
Is the new sensor a longer-shank design?
I'm a little confused about the mention of the muffler, as the the O2 sensor is usually found far-upstream from the muffler.
Old Jun 29, 2018 | 09:11 AM
For some reason, 02 sensor was non-standard. Not related to muffler, of course.
majobis
Nov 7, 2025 07:21 PM
derekiroc
Oct 27, 2008 11:10 PM
sslee
Aug 17, 2002 01:51 PM
fieromerk
Dec 25, 2001 05:13 PM
Mark305TBI
Apr 20, 2001 02:25 PM
