EBL file conversion
Old Feb 1, 2023 | 07:26 AM
Rebuildman's Avatar
Car: 1990 Corvette, 1985 C-10 1979 Subun
Engine: 350, 406 HSR
Transmission: manual, 200 4r
EBL file conversion
I use the EBL P4 board in my ecm for tuning. I am aware that this uses its own code for the files.
I want to use an EBL file and burn it to a stock chip to work with a stock ecm, no EBL P4 installed.
Is there a file conversion process I need to follow first?
Thanks!
Old Feb 1, 2023 | 11:17 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: EBL file conversion
Will need to copy the tables over to an $8D BIN. I can see the AE, SA, and VE, then maybe the injector compensation tables. But even at that the two code bases handle things a little differently.
There is no easy way to do a direct 1-for-1 conversion.
RBob.
Old Feb 2, 2023 | 05:39 AM
Rebuildman's Avatar
RBob.
O.K. Thanks!
BWilcox
Dec 24, 2020 07:52 AM
nbays1975
Aug 31, 2007 02:07 PM
seiplentz
May 19, 2006 07:55 PM
SunsetInjected
Feb 15, 2006 09:47 PM
WHITE87GTA
Oct 17, 2003 08:38 PM
