bin files not showing up on flash & burn
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
I like to save as a new file anytime i do modifications to my tune so i can reference back to old tune. when i go to load file to buffer on flash&burn, the new bin files are not showing up only previous files. I can see them in the folder on file explorer and in tuning software, just not when i try to flash. I have also tried a copy and paste of bin files in the same folder and those new pasted bins do not show up as well. Any ideas?
Car: '86MCSS
Engine: 396 .030"
Transmission: M20
Re: bin files not showing up on flash & burn
If the chip you're using for your modified tune is bigger than the OEM chip, then chances are you're using offsets to burn the chip. I believe you need to setup flash and burn to read the same line address that the offset has been written to.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Car: 91 Z28
I'm using 27sf512 chips 32k file with buffer start/end 000000-007FFF and chip start/end 008000-00FFFF. I dont think that has to do with the files not showing up or maybe i wasnt clear on my issue. When i click "load file to buffer" it brings up the folder i have bins stored in but doesn't populate all bins i have in that folder. I've been tuning without issue since mid 2000's and haven't seen this happen before.
Engine: Lb9
Transmission: M20
I haven’t seen that, I’d try a pc reboot and check to make sure properties arnt a hidden file. Bin can be found and loaded into tuner pro ?
Car: 91 Z28
I've went through the basic steps of reboot and checked to see if the files are hidden, they aren't. I can see the bins with tuner pro and load and modify them just fine. I even see them on windows file browser. Just doesn't show up with flash&burn, even the bins that do show in flash&burn if I create an exact copy by copy/paste, the new copy doesn't show up. I'm starting to think the program may have became corrupt. Does anyone have the install file for flash&burn?
Engine: Lb9
Transmission: M20
Car: 91 Z28
jammin
Sep 14, 2008 03:47 PM
