EBL not showing WB readings correctly
Old Aug 12, 2023 | 11:30 AM
m300slr's Avatar
Car: 1985 Z28
Axle/Gears: 3.90 10 bolt eaton posi
Hey all,
I have a innovate LC2 hooked up and I noticed on WUD it shows 9-10 AFR while my narrow band is right at 13-14 ish.. When I use the Innovate Logworks software the WB AFR is right where it is supposed to be. In WUD I have everything set up correctly 0v =7.35 5v = 22.... Not sure whats going on.
Old Aug 12, 2023 | 11:41 AM
ULTM8Z's Avatar
Re: EBL not showing WB readings correctly
Maybe verify the output voltages going to the ECM from the WB?
Old Aug 12, 2023 | 03:12 PM
m300slr's Avatar
Car: 1985 Z28
well I feel like an idiot... I took out the ECU and double checked which terminal I put the WB in I thought I put it in 0... Turns out I put it in 1. Kinda interesting that I was still getting some sort of reading out of #0.. Changed my input to #1 and the sensor is on par with the other now... Thanks for helping.
Dr.E
Nov 16, 2017 05:22 PM
dfarr67
Mar 7, 2016 10:33 AM
pwdbychevy
Apr 8, 2015 09:48 AM
pellmanm
May 16, 2005 11:16 AM
BMmonteSS
Nov 15, 2004 04:06 PM
