what table(s) in 6e would give the "pump shot effect?"
Old Jan 31, 2002 | 02:13 PM
formula5's Avatar
I posted about this before but did'nt get a definitive answer.
Old Feb 1, 2002 | 10:29 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Re: what table(s) in 6e would give the "pump shot effect?"
It's known as Acceleration Enrichment; there are several tables dealing with this.
Old Feb 2, 2002 | 01:28 AM
formula5's Avatar
Could you go into greater detail?
Old Feb 2, 2002 | 09:02 AM
89vette's Avatar
Are you using tunercat? GMEPro is much better for changing these tables. There is actually 4 of them to play with. What's the problem? Do you have a bog?
Old Feb 3, 2002 | 12:00 AM
formula5's Avatar
Yes I have a bit of a lag when I stab the pedal,I have a 406 tpi.My 6E tdf is defined fairly well.What tables in tunercat will help?I really have two issues.The initial bog and the rpms seem faster than the fuel delivery.
Old Feb 3, 2002 | 09:27 AM
89vette's Avatar
I have Tunercat $6E version C and there are no defined tables for AE fuel. Again, in GMEPro there are 4 tables to play with. Contact Terry Kelley or ask Tuner cat if there is an updated version. You might try turning up your fuel pressure also.
Jason
Old Feb 3, 2002 | 09:51 AM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
Version C of TC's $6E is way old. I think I am up to V or maybe W. But anyways there are 4 tables in there affecting Power Enrichment. Make sure you get the latest version from TC. Yea I know its easy to forget about it. But until they create a mailing list for their customers, you have to ask for the updates.
Old Feb 3, 2002 | 11:28 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
That's one thing I like about TunerCat, they are ALWAYS updating their TDFs when they become aware of a new table/constant that is useful for tuning.
Old Feb 3, 2002 | 03:56 PM
formula5's Avatar
I have 6e version u,I think.It's got way more tables than that c version.I know there is a way to do it.
Old Feb 3, 2002 | 04:50 PM
89vette's Avatar
Acceleration Enrichment (AE) factor vs change in LV8 is one and LV8 AE multiplier vs coolant temp is another one. One richens when load changes and the other varies with coolant temp. A colder motor needs more AE fuel.
Old Feb 4, 2002 | 02:06 PM
formula5's Avatar
What about winbin,does it hav the tables?
Old Feb 4, 2002 | 02:45 PM
89vette's Avatar
I don't have winbin so I couldn't tell you. Did you get me email?
Jason
Old Feb 4, 2002 | 03:45 PM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
Yes it does, look under the arrays.
Old Feb 4, 2002 | 08:37 PM
formula5's Avatar
Ok now I found em in winbin.Tunercat does have the "Acceleration Enrichment (AE) factor vs change in LV8".I just over looked it.Well how far should I go for a healthy shot,0.247 enough(generally speaking)?
Old Feb 5, 2002 | 11:20 PM
formula5's Avatar
Old Feb 6, 2002 | 09:08 AM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
Well did you try the .247? I am trying .22 all the way down from 0 LV8 to 256 LV8 this afternoon. I willupdate tomarrow.
fasteddi
Sep 2, 2015 10:29 AM
TRAXION
May 7, 2003 02:58 PM
prscarf
Nov 7, 2001 07:47 PM
89vette
Jul 6, 2001 03:18 PM
Mark305TBI
Oct 1, 2000 08:42 PM
